| DC_neun_vierzehn |
May 8 2021, 04:06 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 640 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
I have a '73 2.0.
I purchased a Blaupunkt Frankfurt radio to replace the original radio (well it was the original Sapphire, but it's definitely an early 70's radio and fit into the dash plate like a Sapphire). I removed the old radio from the dash. When I try to drop in the Blaupunkt into the plate, the center window hole appears to be too small for the Blaupunkt. Seems like it's about a mm or two too small. Anybody else ever encountered this when trying to install a Blaupunkt Frankfurt? Do I need to get a different dash plate for the Blaupunkt Frankfurt? Is there a different plate available anywhere? I'd rather not file or dremel the hole bigger. |
| 914Sixer |
May 9 2021, 11:09 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,453 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
So what your saying is the Dash piece is too small , NOT the faceplate shown here. Sapphire dash plate is plastic, the Blaupunkt is metal.
| DC_neun_vierzehn |
May 9 2021, 04:01 PM
So what your saying is the Dash piece is too small , NOT the faceplate shown here. Sapphire dash plate is plastic, the Blaupunkt is metal. Correct. I obviously won't be able to use the radio's black faceplate in the 914 dash. It's the chrome nose piece that snaps on and off that appears to be 2-3 mm too big. I know the radio comes through the dash plate and then the chrome piece pops on from the front. It almost fits, but it won't click into the radio because the dash plate hole appears to be a hair too small. |
DC_neun_vierzehn Blaupunkt Frankfurt radio fitment issue? May 8 2021, 04:06 PM
914Sixer This is what your plate should look like. Round n... May 8 2021, 06:24 PM
DC_neun_vierzehn
This is what your plate should look like. Round ... May 8 2021, 09:22 PM
Mike Fitton I believe he is talking about the dash plate openi... May 8 2021, 08:00 PM
Mike Fitton Post a picture of your radio with the chrome trim ... May 9 2021, 05:57 AM
DC_neun_vierzehn
Post a picture of your radio with the chrome trim... May 9 2021, 08:28 PM
914Sixer Sapphire plate is COMPLETELY different than Blaupu... May 9 2021, 06:11 AM
DC_neun_vierzehn The nose hole in the upholstered dash plate is too... May 9 2021, 09:31 AM
gereed75 These are made specifically for each radio. You c... May 9 2021, 07:40 PM
Mike Fitton That chrome piece will not work it is designed to ... May 10 2021, 02:22 PM
DC_neun_vierzehn
That chrome piece will not work it is designed to... May 11 2021, 02:01 PM
Mike Fitton
That chrome piece will not work it is designed t... May 11 2021, 03:06 PM
Mike Fitton You could also use the faceplate you have in post ... May 10 2021, 02:25 PM
rfinegan I used the din mount on my Koln...
May 10 2021, 05:55 PM
DC_neun_vierzehn Dremeled the hole a couple of mms taller (off the ... May 15 2021, 08:40 AM
DC_neun_vierzehn 6 pin Bluetooth plugged into the back of the radio... May 15 2021, 08:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:22 AM |
