Missing Oil Pressure Valve? |
bkrantz |
May 9 2021, 01:36 PM
914 Guru Group: Members Posts: 7,803 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
As I put my 2056 2.0 liter engine together, I find things that seem to be missing. This includes what the parts schematic shows as a second oil pressure relief valve (#19 and 21). I have the other valve (#18 and 20), and I am pretty sure #19 was not present when I tore the engine apart.
Attached thumbnail(s) |
mate914 |
May 10 2021, 05:44 AM
Matt Group: Members Posts: 758 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
Why did they make that change? The 2.0 im running now looks like that, with no hole tapped into case. It also had no spot to put taco plate with temp sensor.
Matt |
Mark Henry |
May 10 2021, 06:23 AM
Why did they make that change? The 2.0 im running now looks like that, with no hole tapped into case. It also had no spot to put taco plate with temp sensor. Matt They stopped drilling them for the bus with hydraulic lifters. The circuit is not needed, in fact I disable this relief on performance builds. I don't think I've seen a T4 case with no taco plate. |
Lo-Fi Version | Time is now: 9th June 2024 - 05:14 PM |
