> Blaupunkt Frankfurt radio fitment issue?, Doesn't seem to fit in the dash where the original radio was.
DC_neun_vierzehn
post May 8 2021, 04:06 PM
I have a '73 2.0.
I purchased a Blaupunkt Frankfurt radio to replace the original radio (well it was the original Sapphire, but it's definitely an early 70's radio and fit into the dash plate like a Sapphire).
I removed the old radio from the dash. When I try to drop in the Blaupunkt into the plate, the center window hole appears to be too small for the Blaupunkt. Seems like it's about a mm or two too small.
Anybody else ever encountered this when trying to install a Blaupunkt Frankfurt?
Do I need to get a different dash plate for the Blaupunkt Frankfurt? Is there a different plate available anywhere?
I'd rather not file or dremel the hole bigger.
Mike Fitton
post May 10 2021, 02:25 PM
You could also use the faceplate you have in post #7 above and buy this 914 DIN faceplate from AA.
http://www.autoatlanta.com/Porsche-Din-Rad...14552040A2.html
DC_neun_vierzehn   Blaupunkt Frankfurt radio fitment issue?   May 8 2021, 04:06 PM
914Sixer   This is what your plate should look like. Round n...   May 8 2021, 06:24 PM
DC_neun_vierzehn   This is what your plate should look like. Round ...   May 8 2021, 09:22 PM
Mike Fitton   I believe he is talking about the dash plate openi...   May 8 2021, 08:00 PM
Mike Fitton   Post a picture of your radio with the chrome trim ...   May 9 2021, 05:57 AM
DC_neun_vierzehn   Post a picture of your radio with the chrome trim...   May 9 2021, 08:28 PM
914Sixer   Sapphire plate is COMPLETELY different than Blaupu...   May 9 2021, 06:11 AM
DC_neun_vierzehn   The nose hole in the upholstered dash plate is too...   May 9 2021, 09:31 AM
914Sixer   So what your saying is the Dash piece is too small...   May 9 2021, 11:09 AM
DC_neun_vierzehn   So what your saying is the Dash piece is too smal...   May 9 2021, 04:01 PM
gereed75   These are made specifically for each radio. You c...   May 9 2021, 07:40 PM
Mike Fitton   That chrome piece will not work it is designed to ...   May 10 2021, 02:22 PM
DC_neun_vierzehn   That chrome piece will not work it is designed to...   May 11 2021, 02:01 PM
Mike Fitton   That chrome piece will not work it is designed t...   May 11 2021, 03:06 PM
Mike Fitton   You could also use the faceplate you have in post ...   May 10 2021, 02:25 PM
rfinegan   I used the din mount on my Koln...   May 10 2021, 05:55 PM
DC_neun_vierzehn   Dremeled the hole a couple of mms taller (off the ...   May 15 2021, 08:40 AM
DC_neun_vierzehn   6 pin Bluetooth plugged into the back of the radio...   May 15 2021, 08:41 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:18 PM
