| DC_neun_vierzehn |
May 8 2021, 04:06 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 640 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
I have a '73 2.0.
I purchased a Blaupunkt Frankfurt radio to replace the original radio (well it was the original Sapphire, but it's definitely an early 70's radio and fit into the dash plate like a Sapphire). I removed the old radio from the dash. When I try to drop in the Blaupunkt into the plate, the center window hole appears to be too small for the Blaupunkt. Seems like it's about a mm or two too small. Anybody else ever encountered this when trying to install a Blaupunkt Frankfurt? Do I need to get a different dash plate for the Blaupunkt Frankfurt? Is there a different plate available anywhere? I'd rather not file or dremel the hole bigger. |
| Mike Fitton |
May 10 2021, 02:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 629 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest
That chrome piece will not work it is designed to push in from behind on the early 911's. You need the chrome trim piece that has the recessed center bar and is designed to install from the front.
| DC_neun_vierzehn |
May 11 2021, 02:01 PM
| Mike Fitton |
May 11 2021, 03:06 PM
That chrome piece will not work it is designed to push in from behind on the early 911's. You need the chrome trim piece that has the recessed center bar and is designed to install from the front. ![]() Any idea where I can get one? They are rare and expensive, PM sent on this. |
DC_neun_vierzehn Blaupunkt Frankfurt radio fitment issue? May 8 2021, 04:06 PM
914Sixer This is what your plate should look like. Round n... May 8 2021, 06:24 PM
DC_neun_vierzehn
This is what your plate should look like. Round ... May 8 2021, 09:22 PM
Mike Fitton I believe he is talking about the dash plate openi... May 8 2021, 08:00 PM
Mike Fitton Post a picture of your radio with the chrome trim ... May 9 2021, 05:57 AM
DC_neun_vierzehn
Post a picture of your radio with the chrome trim... May 9 2021, 08:28 PM
914Sixer Sapphire plate is COMPLETELY different than Blaupu... May 9 2021, 06:11 AM
DC_neun_vierzehn The nose hole in the upholstered dash plate is too... May 9 2021, 09:31 AM
914Sixer So what your saying is the Dash piece is too small... May 9 2021, 11:09 AM
DC_neun_vierzehn
So what your saying is the Dash piece is too smal... May 9 2021, 04:01 PM
gereed75 These are made specifically for each radio. You c... May 9 2021, 07:40 PM
Mike Fitton You could also use the faceplate you have in post ... May 10 2021, 02:25 PM
rfinegan I used the din mount on my Koln...
May 10 2021, 05:55 PM
DC_neun_vierzehn Dremeled the hole a couple of mms taller (off the ... May 15 2021, 08:40 AM
DC_neun_vierzehn 6 pin Bluetooth plugged into the back of the radio... May 15 2021, 08:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:22 AM |
