| BillJ |
May 12 2021, 07:12 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,355 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None
I recently picked up a oil pressure gauge for my center console and need to get the sender side. Does anyone make a nice kit that works with our type 4s? Have seen a custom setup with using the oil pressure sensor port and creating a "t" to use both and can probably piece that together myself but a plug and play solution would be nice too. I have a VDO gauge that runs from 0-60psi and 0-5 kgf/cm2 and labeled on face with "I" at the 12 o'clock position and "522" at the 2 o'clock position. back has 3 spades.
I would like to preserve the light as well in the dash so having a solution for both is important to me. Any help appreciated! |
| bbrock |
May 12 2021, 07:42 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
They used to sell dual pole senders that let you connect both a gauge and the dash light. I bought mine over 30 years ago so don't know if they are still available.
BillJ Oil Pressure Gauge Sender Kit? May 12 2021, 07:12 AM
brant Buy a dual pole sensor
You should not really get ... May 12 2021, 07:45 AM
BillJ Oh great! So would toss the old single pole s... May 12 2021, 07:54 AM
FlacaProductions Here's the dual pole - and while they sell it,... May 12 2021, 07:57 AM
BillJ Definitely interesting. They also sell a splitter... May 12 2021, 08:14 AM
mate914 I think some on here use a paintball gun hose. I o... May 12 2021, 09:15 AM
barefoot There are threads here that discuss adapting a sho... May 12 2021, 09:21 AM
914werke & a way to ground the senders ~ May 12 2021, 10:03 AM
johnhora BillJ
I have this good used VDO made in Germany s... May 12 2021, 10:24 AM
BillJ I think I am going to get the predrilled block and... May 12 2021, 11:34 AM
aharder
I think some on here use a paintball gun hose. I ... May 12 2021, 06:16 PM
FlacaProductions I may be doing this install next week and the engi... May 12 2021, 07:02 PM
BillJ
I may be doing this install next week and the eng... May 13 2021, 05:16 AM
euro911 Those look like they'd work for great the CHT ... May 12 2021, 11:40 PM
FlacaProductions
Those look like they'd work for great the CHT... May 13 2021, 07:47 AM
Highland Hi @BillJ , thought I'd post a picture of wha... May 13 2021, 02:26 PM
HansJan
Hi [b]@[url=http://www.914world.com/bbs2/index.p... May 13 2021, 08:31 PM
BillJ Thanks a ton for the picture that definitely helps... May 13 2021, 02:47 PM
aharder Pictures of my set up for both plus 1 in the engin... May 13 2021, 09:23 PM
930cabman I am looking at doing something similar, but hard ... May 14 2021, 04:59 AM
BillJ I have read that hard pipe runs the risk of cracki... May 17 2021, 10:04 AM
BillJ Are brake lines (928) plug and play or will i need... May 17 2021, 10:11 AM
IVGUY Heres the part I used and I fabbed up a mount for ... May 29 2024, 10:21 PM
BillJ Hi! That particular 914 now lives with new ow... May 30 2024, 10:31 AM
IVGUY Yes i have a small rubber washer under the bracket... May 30 2024, 06:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:00 AM |
