| BillJ |
May 12 2021, 07:12 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,355 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None
I recently picked up a oil pressure gauge for my center console and need to get the sender side. Does anyone make a nice kit that works with our type 4s? Have seen a custom setup with using the oil pressure sensor port and creating a "t" to use both and can probably piece that together myself but a plug and play solution would be nice too. I have a VDO gauge that runs from 0-60psi and 0-5 kgf/cm2 and labeled on face with "I" at the 12 o'clock position and "522" at the 2 o'clock position. back has 3 spades.
I would like to preserve the light as well in the dash so having a solution for both is important to me. Any help appreciated! |
| BillJ |
May 12 2021, 08:14 AM
Definitely interesting. They also sell a splitter block to use the stock sender for the idiot light at 2psi and a single pole for the pressure gauge. Probably best bet is to simply call those guys up and talk through the need.
BillJ Oil Pressure Gauge Sender Kit? May 12 2021, 07:12 AM
bbrock They used to sell dual pole senders that let you c... May 12 2021, 07:42 AM
brant Buy a dual pole sensor
You should not really get ... May 12 2021, 07:45 AM
BillJ Oh great! So would toss the old single pole s... May 12 2021, 07:54 AM
FlacaProductions Here's the dual pole - and while they sell it,... May 12 2021, 07:57 AM
mate914 I think some on here use a paintball gun hose. I o... May 12 2021, 09:15 AM
barefoot There are threads here that discuss adapting a sho... May 12 2021, 09:21 AM
914werke & a way to ground the senders ~ May 12 2021, 10:03 AM
johnhora BillJ
I have this good used VDO made in Germany s... May 12 2021, 10:24 AM
BillJ I think I am going to get the predrilled block and... May 12 2021, 11:34 AM
aharder
I think some on here use a paintball gun hose. I ... May 12 2021, 06:16 PM
FlacaProductions I may be doing this install next week and the engi... May 12 2021, 07:02 PM
BillJ
I may be doing this install next week and the eng... May 13 2021, 05:16 AM
euro911 Those look like they'd work for great the CHT ... May 12 2021, 11:40 PM
FlacaProductions
Those look like they'd work for great the CHT... May 13 2021, 07:47 AM
Highland Hi @BillJ , thought I'd post a picture of wha... May 13 2021, 02:26 PM
HansJan
Hi [b]@[url=http://www.914world.com/bbs2/index.p... May 13 2021, 08:31 PM
BillJ Thanks a ton for the picture that definitely helps... May 13 2021, 02:47 PM
aharder Pictures of my set up for both plus 1 in the engin... May 13 2021, 09:23 PM
930cabman I am looking at doing something similar, but hard ... May 14 2021, 04:59 AM
BillJ I have read that hard pipe runs the risk of cracki... May 17 2021, 10:04 AM
BillJ Are brake lines (928) plug and play or will i need... May 17 2021, 10:11 AM
IVGUY Heres the part I used and I fabbed up a mount for ... May 29 2024, 10:21 PM
BillJ Hi! That particular 914 now lives with new ow... May 30 2024, 10:31 AM
IVGUY Yes i have a small rubber washer under the bracket... May 30 2024, 06:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:00 AM |
