trailing arm bushing replacement, need bushing source and advice |
914 RZ-1 |
May 12 2021, 12:21 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I need to replace the trailing arm bushings. These are pressed in to the trailing arm, correct? The bushings are not listed as an item on the PET, it just notes that the trailing arm comes with the bushings. 914rubber doesn't seem to have them. Pelican does (https://www.pelicanparts.com/More_Info/993015335.htm?pn=99-3015-335-M523&SVSVSI=5874&DID=12870), but they are the ones I'm told squeak over time. Is there another source for these? I need a part number as well, unless the Pelican part number (Part #: 99-3015-335-M523) is correct.
What is involved in replacing these? I'm assuming I need to remove the rear trailing arms, which involves removing the brake lines, the e-brake, wheels, etc. Anything else I should look out for? I have a friend who has a press for getting the bearings in and out. Any special tools needed? Thanks! |
MM1 |
May 12 2021, 06:24 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
I researched this quite a bit too, Padawan . . .go with Elephant racing . . .not always easy to get a quote for just the bushings (if you know someone with the installation kit - which you'll want to use) . . .I finally got a quote of $200-ish for just the bushings around a year ago . . .took a little bit of persuasion though as I recall.
Lo-Fi Version | Time is now: 2nd June 2024 - 03:09 AM |
