> Oil Pressure Gauge Sender Kit?
BillJ
post May 12 2021, 07:12 AM
I recently picked up a oil pressure gauge for my center console and need to get the sender side. Does anyone make a nice kit that works with our type 4s? Have seen a custom setup with using the oil pressure sensor port and creating a "t" to use both and can probably piece that together myself but a plug and play solution would be nice too. I have a VDO gauge that runs from 0-60psi and 0-5 kgf/cm2 and labeled on face with "I" at the 12 o'clock position and "522" at the 2 o'clock position. back has 3 spades.
I would like to preserve the light as well in the dash so having a solution for both is important to me.
Any help appreciated!
euro911
post May 12 2021, 11:40 PM
Those look like they'd work for great the CHT sensor installation/removal/replacement (XX-mm) ... not sure if you'd need one for the oil pressure sensor (IMG:style_emoticons/default/confused24.gif)
FlacaProductions
post May 13 2021, 07:47 AM
QUOTE(euro911 @ May 12 2021, 10:40 PM) *
wouldn't need them for the stock oil pressure sensor, no - I'd need it for the installation of the hose in that same hole (obviously) for a remote oil pressure sender. it's gotta be tight with the engine in and the tins on. my real issue is that i'm in a different state than my 914 and i only get short bursts of time to mess around with it so i have to try to visualize and plan do research while I'm away.
search "line socket" and the appropriate size and you'll find options.
that pic came from amazon but there are numerous sources.
post a WTB ad here for a 42 Draft Design kit - maybe someone still has one on a shelf.
this is what they look like:
https://store.ngpracing.com/42-draft-design...cation-kit.html
BillJ   Oil Pressure Gauge Sender Kit?   May 12 2021, 07:12 AM
bbrock   They used to sell dual pole senders that let you c...   May 12 2021, 07:42 AM
brant   Buy a dual pole sensor You should not really get ...   May 12 2021, 07:45 AM
BillJ   Oh great! So would toss the old single pole s...   May 12 2021, 07:54 AM
FlacaProductions   Here's the dual pole - and while they sell it,...   May 12 2021, 07:57 AM
BillJ   Definitely interesting. They also sell a splitter...   May 12 2021, 08:14 AM
mate914   I think some on here use a paintball gun hose. I o...   May 12 2021, 09:15 AM
barefoot   There are threads here that discuss adapting a sho...   May 12 2021, 09:21 AM
914werke   & a way to ground the senders ~   May 12 2021, 10:03 AM
johnhora   BillJ I have this good used VDO made in Germany s...   May 12 2021, 10:24 AM
BillJ   I think I am going to get the predrilled block and...   May 12 2021, 11:34 AM
aharder   I think some on here use a paintball gun hose. I ...   May 12 2021, 06:16 PM
FlacaProductions   I may be doing this install next week and the engi...   May 12 2021, 07:02 PM
BillJ   I may be doing this install next week and the eng...   May 13 2021, 05:16 AM
euro911   Those look like they'd work for great the CHT ...   May 12 2021, 11:40 PM
FlacaProductions   Those look like they'd work for great the CHT...   May 13 2021, 07:47 AM
Highland   Hi @BillJ , thought I'd post a picture of wha...   May 13 2021, 02:26 PM
HansJan   Hi [b]@[url=http://www.914world.com/bbs2/index.p...   May 13 2021, 08:31 PM
BillJ   Thanks a ton for the picture that definitely helps...   May 13 2021, 02:47 PM
aharder   Pictures of my set up for both plus 1 in the engin...   May 13 2021, 09:23 PM
930cabman   I am looking at doing something similar, but hard ...   May 14 2021, 04:59 AM
BillJ   I have read that hard pipe runs the risk of cracki...   May 17 2021, 10:04 AM
BillJ   Are brake lines (928) plug and play or will i need...   May 17 2021, 10:11 AM
IVGUY   Heres the part I used and I fabbed up a mount for ...   May 29 2024, 10:21 PM
BillJ   Hi! That particular 914 now lives with new ow...   May 30 2024, 10:31 AM
IVGUY   Yes i have a small rubber washer under the bracket...   May 30 2024, 06:45 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:08 AM
