Tip on repairing the Jack Post |
rick 918-S |
May 14 2021, 05:59 AM
Hey nice rack! -Celette Group: Members Posts: 20,493 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I am not sure this topic has been addressed. In case it has here it is again. I thought this would be helpful. When locating the jack post and cover either on a new part or just repairing the existing long try this. Anyone that has tried to get the post centered can relate to the frustration.
I use the outer rocker cover to find center. The nut that is welded inside the inner rocker is centered on the jack post or vise-versa. Clamp your repair section in place. Use the rocker cover to find the inner nut location, Mark center. Then use Super Glue on the post, Slip the cover over the post until the glue sets. Pull off the post cover (support) and you are ready to tack it. Once you hit it with the welder it will break the super glue connection but you will be able to get it set in place for an easy jack post support installation. |
Lo-Fi Version | Time is now: 9th June 2024 - 02:42 PM |
