rear suspension, re-assembly questions |
Speedo |
May 17 2021, 03:51 PM
Senior Member Group: Members Posts: 529 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains |
Bolting back up the rear control arms. Where the front of it attaches to the chassis, shouldn't there be a large flat washer on both sides under the big nut? PET shows a washer on the inside.
Next, how do I determine how many shims to use in my link bearing initial setup. Is there a measurement I can take? I have two 3mm and three 4mm. Be nice to get this dialed in at the start. On illustration 501-00 item #4 is called a stopper. Is that metal or plastic and what does it do? How do I determine what spring weight I have on my rear coilovers? Measure the diameter of the spring steel itself? Thanks! |
rgalla9146 |
May 18 2021, 04:28 AM
Advanced Member Group: Members Posts: 4,564 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
On '75-'76 (?) I'm pretty sure there are no 'stoppers' the holes are welded shut. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:27 PM |
