> Relay board repair, How I did mine
Bartlett 914
post Oct 8 2010, 12:13 PM
I have a relay board that was giving me grief. Several times the car would not start. Cleaning the fuse seemed to help but once in a great while the problem returned. The problem was the fuse holder. As these connections get dirty, they heat up. The problem in my case was aggravated by the use of the heater fan. This draws more current and made the problem of the fuse heating worse. I have some before and after pictures. You can see how the fuse holder is leaning back. If you look closer, you can see melted plastic where it is mounted. My solution was to install a new fuse holder. I recently installed an Engman fuse panel so now all my fuses will be the newer style. No more VW fuses! Te resin I used was Vagabond Model-cast 3521S black. This stuff flows like water and dries pretty fast. It is hard when cured and looks real nice. The biggest problem is the resin flowing through the board and leaking. I knew this would happen and I taped where I thought it would leak out. I missed the voltage regulator socket. It looked fine from the rear but it leaked real bad. I had quite a time sealing this up. If you do this, try epoxy first to seal where the pins come through.
Olympic 914
post May 29 2021, 06:31 AM
I have used multiple coats of rubberized undercoating spray.
This board was working fine, but I wanted to seal up the fine cracks that appeared in the original potting.
Didn't want to use something that would be hard to remove if I had to work on it later.
Bartlett 914   Relay board repair   Oct 8 2010, 12:13 PM
Bartlett 914   kjyf   Oct 8 2010, 12:15 PM
Vacca Rabite   kjyf Hey, I know this is an old thread, but I m...   Aug 21 2018, 07:17 AM
Bartlett 914   kjyf Hey, I know this is an old thread, but I ...   Aug 21 2018, 08:06 AM
porschetub   [quote name='Vacca Rabite' post='2640989' date='A...   Aug 21 2018, 11:15 PM
Vacca Rabite   Seems when they are shite they don't work ag...   Aug 22 2018, 08:00 AM
Bartlett 914   Seems when they are shite they don't work a...   Aug 22 2018, 08:33 AM
Vacca Rabite   I really wished I had soldered the connections. ...   Aug 23 2018, 11:08 AM
Bartlett 914   I really wished I had soldered the connections....   Aug 23 2018, 03:18 PM
bbrock   [quote name='Bartlett 914' post='1380640' date='O...   Aug 21 2018, 08:16 AM
914_teener   kjyf Hey, I know this is an old thread, but I ...   Aug 21 2018, 09:21 AM
bbrock   soldered all the riveted connectiions. Great ...   Aug 21 2018, 09:42 AM
Drums66   ..Came out decent... :shades2: what did you use o...   Oct 8 2010, 12:21 PM
Bartlett 914   ..Came out decent... :shades2: what did you use ...   Oct 8 2010, 12:38 PM
Drums66   ...Excellent...thank you for the reply sir :shades...   Oct 8 2010, 03:02 PM
MarkV   I thought about soldering but wasn't sure I ha...   Aug 21 2018, 08:15 PM
Bartlett 914   I thought about soldering but wasn't sure I h...   Aug 21 2018, 09:23 PM
Bartlett 914   Well Zach got me interested in this board again. I...   Aug 23 2018, 06:43 PM
DTMLGND   Hi! I just acquired my ‘74 2.0 a few months ...   Dec 16 2018, 01:36 AM
930cabman   Again? I am addressing the relay board and do no...   May 28 2021, 03:12 PM
914-VI   Again? I am addressing the relay board and do n...   Jun 8 2021, 08:48 AM
914-VI   Again? I am addressing the relay board and do ...   Jun 8 2021, 08:59 AM
Olympic 914   I have used multiple coats of rubberized undercoat...   May 29 2021, 06:31 AM
930cabman   It will work for sure, you can make boats out of t...   Jun 8 2021, 09:51 AM
GeorgeKopf   I will be doing this shortly. Now is the time sin...   Jun 29 2021, 08:01 PM
- Lo-Fi Version Time is now: 10th November 2026 - 07:39 AM
