Any OEM design 911 muffler up to a 2.4L fit? |
Tdskip |
May 30 2021, 03:58 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
From the research I’ve done it appears that 2.4L and earlier 912 mufflers fit our /6 builds but I wanted to double check.
Thanks! |
914werke |
Jun 7 2021, 10:16 AM
"I got blisters on me fingers" Group: Members Posts: 10,116 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
One Exception. 1976 912E muffler will fit. It is the same part as a 2.0 914. NOPE (IMG:style_emoticons/default/dry.gif) Not the same. Similar but will not bolt up to any 911/914/6 solution nor the 914/4. The Body of the muffler is identical, the flanges are specific to the 912e one yrs only HE's. They are still 3 bolt attachment but upside down from the /4 mounting. Correct (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/hijacked.gif) @mb911 Ben before I begin a exhaustive (see what I did there (IMG:style_emoticons/default/shades.gif) )search, I figure Ill ask the muffler expert. Do you know if the spacing / or tube inlet measurement is the same for the 914/4 & 912e muffler variants ? In other words if I mod a 914 2.0L banana to apply the correct flanges for the 912e will it attach / fit the 912e HE's? |
mb911 |
Jun 7 2021, 10:40 AM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
One Exception. 1976 912E muffler will fit. It is the same part as a 2.0 914. NOPE (IMG:style_emoticons/default/dry.gif) Not the same. Similar but will not bolt up to any 911/914/6 solution nor the 914/4. The Body of the muffler is identical, the flanges are specific to the 912e one yrs only HE's. They are still 3 bolt attachment but upside down from the /4 mounting. Correct (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/hijacked.gif) @mb911 Ben before I begin a exhaustive (see what I did there (IMG:style_emoticons/default/shades.gif) )search, I figure Ill ask the muffler expert. Do you know if the spacing / or tube inlet measurement is the same for the 914/4 & 912e muffler variants ? In other words if I mod a 914 2.0L banana to apply the correct flanges for the 912e will it attach / fit the 912e HE's? They are not the same. 912e is about the craziest setup on the planet. They come in at an angle. Could it be modified to work ? Yes for sure. Would be a bunch of work. I could see that as a 8-10 hour project to ensure everything lines up , trial fit, weld etc. |
Lo-Fi Version | Time is now: 1st June 2024 - 05:25 AM |
