| Warren914 |
Jun 7 2021, 03:33 PM
Member ![]() ![]() Group: Members Posts: 93 Joined: 26-February 21 From: Nova Scotia Member No.: 25,265 Region Association: Canada |
I have an air conditioning unit for the 914, another part of my 20 year old clutter pile. I'm reluctant to chop the bottom out of the trunk for the huge condensor coil. It would need a new compressor and hopefully a smaller condensor coil could be made to work. How much work to install? Is it worth the effort?
| rgalla9146 |
Jun 8 2021, 10:00 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
This is a welcome discussion as I want to add AC to my car.
I'm hoping some of the expertise shown here can offer an opinion on my idea. I want to take advantage of the vacant area in front of the right rear wheel. Similar to the mounting of the oil tank on a 914 6 I want to place the condenser and a pulling fan behind the passenger door. Yes, I'm willing to open the quarter up to allow flow-thru. The condenser might be as large as 12" x 16" x 1.5 or 2" Appearance aside, can this be adequate cross section ? I realize that while stopped it will not be efficient but underway it improves especially with some scoop arangement. The other components will be an electric compressor and the largest alternator available for a 3.6 Carrera engine. The under dash will be an early 911 Behr unit which includes 2 control knobs. I'll do the fab work myself, my questions are about the concept. TIA Rory Visual aid attached (IMG:style_emoticons/default/idea.gif) Attached thumbnail(s) |
| Chris914n6 |
Jun 8 2021, 04:41 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,528 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
This is a welcome discussion as I want to add AC to my car. I'm hoping some of the expertise shown here can offer an opinion on my idea. I want to take advantage of the vacant area in front of the right rear wheel. Similar to the mounting of the oil tank on a 914 6 I want to place the condenser and a pulling fan behind the passenger door. Yes, I'm willing to open the quarter up to allow flow-thru. The condenser might be as large as 12" x 16" x 1.5 or 2" Appearance aside, can this be adequate cross section ? I realize that while stopped it will not be efficient but underway it improves especially with some scoop arangement. The other components will be an electric compressor and the largest alternator available for a 3.6 Carrera engine. The under dash will be an early 911 Behr unit which includes 2 control knobs. I'll do the fab work myself, my questions are about the concept. TIA Rory Visual aid attached (IMG:style_emoticons/default/idea.gif) Problem is the exit air. It's a tight fit and there is really no place for the air to go and nothing pulling it thru, so it won't be nearly as effective as the engine lid mount. |
| rgalla9146 |
Jun 9 2021, 06:15 AM
This is a welcome discussion as I want to add AC to my car. I'm hoping some of the expertise shown here can offer an opinion on my idea. I want to take advantage of the vacant area in front of the right rear wheel. Similar to the mounting of the oil tank on a 914 6 I want to place the condenser and a pulling fan behind the passenger door. Yes, I'm willing to open the quarter up to allow flow-thru. The condenser might be as large as 12" x 16" x 1.5 or 2" Appearance aside, can this be adequate cross section ? I realize that while stopped it will not be efficient but underway it improves especially with some scoop arangement. The other components will be an electric compressor and the largest alternator available for a 3.6 Carrera engine. The under dash will be an early 911 Behr unit which includes 2 control knobs. I'll do the fab work myself, my questions are about the concept. TIA Rory Visual aid attached (IMG:style_emoticons/default/idea.gif) Problem is the exit air. It's a tight fit and there is really no place for the air to go and nothing pulling it thru, so it won't be nearly as effective as the engine lid mount. I agree. Without an outlet the flow is limited. The solution would be to open the top of the rear quarter (above and behind the rear wheel) which would be effective but not easy to make attractive. Modern Porsche GTs do have inlets in front of and outlets above and behind front wheels. This on a 914GT rear quarter would have a very 'novel' appearance. How about this; run finned radiator tubing the length of the rocker....and back to increase condenser capacity. Of course with some 'suggestion' of a rocker cover....perforated...louvered, whatever to allow exchange. |
Warren914 914 air conditioner Jun 7 2021, 03:33 PM
Warren914 I have an air conditioning unit for the 914, anoth... Jun 7 2021, 03:33 PM
partwerks
I have an air conditioning unit for the 914, anot... Jun 7 2021, 07:02 PM
Warren914 Temperatures today was well in excess of 30c. AC g... Jun 7 2021, 09:23 PM
partwerks
Temperatures today was well in excess of 30c. AC ... Jun 7 2021, 09:31 PM
AZBanks I am building a custom air conditioning system. I ... Jun 7 2021, 07:45 PM
Mark Henry
How often would you really use it, that far Nor... Jun 7 2021, 07:47 PM
Warren914 California is planned for 2023. Europe may be next... Jun 7 2021, 09:36 PM
Rand Lol, trying to un-break the system. Jun 7 2021, 09:45 PM
Rand The best AC in the world is a 914, top off, water ... Jun 7 2021, 09:46 PM
Warren914 Agreed but there have been times I've had too ... Jun 8 2021, 02:34 AM
Mark Henry Any ballpark on the time required to install an AC... Jun 8 2021, 03:56 PM
Warren914 https://bowlsby.net/914/Classic/zTN_Man09.pdf
It ... Jun 9 2021, 06:18 AM
Warren914 Found on Pelican Parts.
http://forums.pelicanparts... Jun 9 2021, 06:23 AM
Warren914 There are many kits for Universal underdash air co... Jun 9 2021, 06:48 AM
Mark Henry Here is an electric AC system build thread.
http:... Jun 9 2021, 07:04 AM
Warren914 Finding a suitable place to install the condensor ... Jun 9 2021, 07:12 AM
Mark Henry Keep looking :D
I likely won't be on-line m... Jun 9 2021, 07:19 AM
Rand Just use a water spritzer and stop embarrasing us.... Jun 9 2021, 03:11 PM
Warren914 It's the woman in that other seat indeed!
... Jun 9 2021, 03:13 PM
Mark Henry
Just use a water spritzer and stop embarrasing us... Jun 9 2021, 03:44 PM
AZBanks
Just use a water spritzer and stop embarrasing us... Jun 9 2021, 06:43 PM
Rand
Just use a water spritzer and stop embarrasing u... Aug 10 2021, 05:12 PM
ClayPerrine We have had a LOT of rain here, and everything is ... Jun 9 2021, 04:37 PM
We have had a LOT of rain here, and everything is... Jun 9 2021, 06:54 PM
Bullethead We participated in a little fun rally a couple of ... Jun 9 2021, 07:18 PM
Warren914 I need to decide on an under dash evaporator unit.... Jun 10 2021, 05:29 PM
76-914 I had a choice of black or chrome on my vintage ai... Jun 10 2021, 07:36 PM
Mark Henry
I had a choice of black or chrome on my vintage a... Jun 12 2021, 05:26 AM
Warren914 That one will likely be chosen. Good concensus amo... Jun 12 2021, 08:48 PM
76-914
[quote name='76-914' post='2922542' date='Ju... Jun 12 2021, 09:12 PM
AZBanks I've seen things like this:
https://www.amazo... Jun 10 2021, 09:09 PM
Warren914 The dealer model is about 5-1/2" tall and 13-... Jun 11 2021, 10:16 AM
Warren914 Considering this underdash unit.
https://www.amaz... Jun 11 2021, 10:34 AM
Warren914 Or the Mark IV from Vintage Air
https://www.vinta... Jun 11 2021, 11:39 AM
Warren914 Or even this one...
https://www.vintageair.com/cus... Jun 11 2021, 03:15 PM
Warren914 I need to match the engine pulley to the clutch pu... Jun 13 2021, 05:32 AM
Mark Henry I'll look for the pulley I have. I know for su... Jun 13 2021, 06:16 AM
Mark Henry This heavy steel pulley I have is for the old styl... Jun 13 2021, 06:45 AM
Warren914 Dug out the York anchor. Big and heavy POS.
Groov... Jun 13 2021, 07:06 AM
Mark Henry Doing some work on Warren's GT lid, I think I... Aug 6 2021, 12:05 PM
Warren914 Interesting approach. How will the new grill trim ... Aug 7 2021, 11:26 PM
Mark Henry
Interesting approach. How will the new grill trim... Aug 10 2021, 02:18 PM
AZBanks How are you going to mount the condenser? Everythi... Aug 10 2021, 03:24 PM
Warren914 Large hose is high pressure vapor from the compres... Aug 10 2021, 08:38 PM
Mark Henry Really??? :huh:
Thanks for letting me know about... Aug 11 2021, 08:04 AM
Warren914 Flip it 180 degrees.
Really??? :huh:
Thanks f... Aug 11 2021, 09:18 AM
AZBanks The big/inflow connector from the compressor is at... Aug 11 2021, 10:52 PM
AZBanks The picture isn't great but you can see a litt... Aug 11 2021, 10:54 PM
AZBanks I can take more close up pictures if you want to s... Aug 11 2021, 10:59 PM
Mark Henry If you have clearance I have all kinds of room, yo... Aug 12 2021, 07:52 AM
AZBanks
If you have clearance I have all kinds of room, y... Aug 13 2021, 12:31 PM
Spocknasty If anyone is interested in an under dash mounted c... Aug 12 2021, 10:52 AM
Mark Henry Not there yet, but yes that's what I figured, ... Aug 14 2021, 06:10 PM
Warren914 Here's the diagram I asked Mark to follow for ... Sep 10 2021, 07:55 AM
Warren914 Here's a dry fit of the VintageAir evaporator.... Oct 4 2021, 08:49 AM
76-914 Run the hoses alongside the passenger side long be... Oct 4 2021, 09:28 AM
78PanamaBrown
Run the hoses alongside the passenger side long b... Feb 26 2023, 06:52 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:03 AM |
