| jmargush |
Jun 10 2021, 02:13 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 501 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I am going to be initially running a newly rebuilt engine on carbs instead of the L-jet and need to get the fuel pump set up for that.
Can I use the stock wiring for the pump? I think I need to have a work around since the AFM won't be installed. Can anyone shed some light on a good way to accomplish this. |
| ejm |
Jun 11 2021, 05:43 AM
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,717 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The fuel pump how to thread works with cars that had D-jet. A separate relay was used with L-jet and those cars would need relays installed on the board.
QUOTE If you wire it as in Sir Andy's How To, does that keep the pump form running if the engine dies? The pump will run as long as the key is on. |
jmargush L-jet to carb fuel pump wiring Jun 10 2021, 02:13 PM
ndfrigi http://www.914world.com/bbs2/index.php?sho...54... Jun 10 2021, 03:39 PM
930cabman +1, thanks to Andy. make sure your fuel supply is ... Jun 10 2021, 04:32 PM
jmargush Awesome,
thanks Jun 10 2021, 07:54 PM
jmargush If you wire it as in Sir Andy's How To, does... Jun 11 2021, 04:54 AM
bdstone914
The fuel pump how to thread works with cars that ... Jun 11 2021, 06:04 AM
jmargush Is there an easy way to signal the pump to shut of... Jul 13 2021, 01:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th June 2026 - 03:23 AM |
