> 2056 build advice requested from those that have been there, June 23 update: original heads rebuilt and will be reinstalled with 96's, will save up for the full upgraded LN
DRPHIL914
post Jun 9 2021, 07:55 AM
Dr. Phil
Ok the short story is my motor is out of the car due to lost compression on #3, found loose intake valve seat no damage no injury to lower end. I have been researching head replacement options and rebuild options, but considering rebuilt head could cost close to $1500, and new basic spec heads are close to $2000 or more, although some new castings from AA , Mark Henry and others are doing rebuilds on those , and tis a great option with out breaking the bank, i find myself looking more at the LN RS+, which is the cream of the crop heads for our motors, and i am 90% sure i will be committing to this purchase , i have the opportunity to get set , SO with that said i would be foolish to not consider upgrading the P&C's too.
the LN heads have the larger valves and are ported polished etc , so i think a 2056 is where i want to go because i can do that build by getting new 96's and not have to to into the lower case and change the cam etc. yes i may do that some day but for now i cant afford that, so i am getting these heads and new 96 P&C's
that way i can use the d-jet tuned for the 2056 but go with upgraded FI soon as i can afford it.
first questions that need to be answered is,
1. do i need to change out my push rods? - this should not change the deck height. I could stay 1911 and just add the heads but while it is hear and new P&C are not that expensive, i am not doing Nikki's cant afford that, but 94 and 96's are same and icould have my cylinders sent to them for hone and bored then coating, or just get new-
so what hgave you all done , has anyone done this, leave the stock cam in place and build the 2056 with the new heads and cylinders?/
the also what else do i need?
Thanks for the advice
Phil
also suggestions on the FI issue as well. what kind of expense am i looking at for a upgraded system?
Phil
- i have a 123ignition distributor so i can continue to use it or change but it works great alone or with d-jet.
colingreene
post Jun 9 2021, 04:45 PM
What kind of fuel injection are you planning.
If its fuel injection with dual carb style throttles I would do what mark recommended and run it on carbs till you can do that.
That way you can put a more aggressive cam in it that will make you some more power without having to handicap it for the factory fuel injection.
I have a Web 86A I think. and its extremely drivable and runs out to about 5500. It will rev to 6 but really its not doing you a ton of good.
Mark Henry
post Jun 11 2021, 05:45 AM
that's what I do!
QUOTE(colingreene @ Jun 9 2021, 06:45 PM) *
Depends on the exhaust, with SSI's for heat I'd keep it the stock plenum. I'd play around with a bigger TB, might even custom build a new center section but I'd keep it single TB.
A mild cam like the 86a is still OK with the above and the aftermarket EFI, but anything bigger than say a mild SCAT C-25 will need upgraded valve train.
To run ITB's you really need a header, cam, heads, valve train, etc.
DRPHIL914
post Jun 11 2021, 06:46 AM
Dr. Phil
QUOTE(Mark Henry @ Jun 11 2021, 07:45 AM) *
i have SS HE and one of Ben's SS muffer with center twin out tips. I have thought about using the slightly larger throttle body, keeping it otherwise stock single TB intake, some guys here have used that van/bus TB so that might work to add just a bit more air in. With a new heads with new valves and springs etc like the LN RS heads, that would go really nice together. FI wise i have a couple choices but something like what PMB is putting together would be an option too, it can keep a lot of the stock looking stuff but gets rid of the MPS, and old brain, new sensors etc.
will see but i can use a tuned d-jet stock stuff for now, as i have decided for sure i am doing the 2056.
DRPHIL914   2056 build advice requested from those that have been there   Jun 9 2021, 07:55 AM
rfinegan   Changing the push rods to Chrome moly has advantag...   Jun 9 2021, 08:48 AM
Bleyseng   I went with the Raby 9550 cam that works well with...   Jun 9 2021, 11:21 AM
DRPHIL914   Changing the push rods to Chrome moly has advanta...   Jun 9 2021, 11:55 AM
nditiz1   When I redid my 2.0, I was only doing a top end. ...   Jun 9 2021, 12:18 PM
JamesM   So, my opinion(s)... I think you are going to be...   Jun 9 2021, 12:42 PM
Mark Henry   So, my opinion(s)... I think you are going to b...   Jun 9 2021, 01:06 PM
colingreene   What kind of fuel injection are you planning. If ...   Jun 9 2021, 04:45 PM
Mark Henry   What kind of fuel injection are you planning. If...   Jun 11 2021, 05:45 AM
DRPHIL914   What kind of fuel injection are you planning. I...   Jun 11 2021, 06:46 AM
mepstein   [quote name='Mark Henry' post='2922627' date='Jun...   Jun 11 2021, 06:59 AM
DRPHIL914   [quote name='Mark Henry' post='2922627' date='Ju...   Jun 11 2021, 07:20 AM
ottox914   Check my sig for details on my 2056 build. I...   Jun 10 2021, 07:20 PM
adolimpio   Just finished my 2056. Started with the original...   Jun 10 2021, 08:42 PM
mepstein   Yes. Spend the $1k now and you will have a go...   Jun 11 2021, 07:29 AM
cgnj   What's the lead time for for HAM to deliver a ...   Jun 11 2021, 02:04 PM
Superhawk996   :popcorn:   Jun 11 2021, 02:32 PM
930cabman   :popcorn: Me too. Thanks everyone for the inpu...   Jun 11 2021, 06:33 PM
Mark Henry   :popcorn: Me too. Thanks everyone for the inp...   Jun 12 2021, 03:27 AM
mihai914   You can also try and find a local shop that knows ...   Jun 11 2021, 03:00 PM
Bleyseng   Yes, Len offers big valve 2.0L heads as I have a s...   Jun 11 2021, 04:19 PM
mb911   Just curious what would a total in budget be on an...   Jun 11 2021, 05:47 PM
JeffBowlsby   See what a slippery slope this can be? Not mentio...   Jun 11 2021, 06:00 PM
adolimpio   If you want to get back on the road quick and chea...   Jun 12 2021, 04:47 AM
DRPHIL914   If you want to get back on the road quick and che...   Jun 23 2021, 06:23 AM
mepstein   If you want to get back on the road quick and che...   Jun 23 2021, 08:25 AM
mepstein   I would keep the same p&c’s if they are good...   Jun 23 2021, 08:22 AM
DRPHIL914   I would keep the same p&c’s if they are goo...   Jun 23 2021, 09:09 AM
rfinegan   Sounds like you will be back on the road in no tim...   Jun 23 2021, 08:38 AM
Bleyseng   Don't use gaskets between the heads and cylind...   Jun 23 2021, 09:22 AM
Mark Henry   Don't use gaskets between the heads and cylin...   Jun 23 2021, 12:25 PM
DRPHIL914   Don't use gaskets between the heads and cyli...   Jun 23 2021, 02:40 PM
Mark Henry   dp   Jun 23 2021, 12:25 PM
mepstein   Don't use gaskets between the heads and cyli...   Jun 23 2021, 12:53 PM
Mark Henry   Maybe, but I doubt if half that much. HP increase...   Jun 23 2021, 12:54 PM
mepstein   Maybe, but I doubt if half that much. HP increas...   Jun 23 2021, 01:21 PM
DRPHIL914   Maybe, but I doubt if half that much. HP increa...   Jun 23 2021, 02:24 PM
Mark Henry   BTW AA only just shipped my skid of parts includin...   Jun 23 2021, 01:14 PM
mepstein   Porsche moved from head gaskets 3.0 to base shims ...   Jun 23 2021, 04:47 PM
Mark Henry   Porsche moved from head gaskets 3.0 to base shims...   Jun 24 2021, 05:26 AM
Mark Henry   You have to measure head cc, if HAM heads cc is st...   Jun 24 2021, 05:38 AM
DRPHIL914   You have to measure head cc, if HAM heads cc is s...   Jun 24 2021, 06:37 AM
mepstein   That's the nice thing about the LN kits. He ha...   Jun 24 2021, 07:02 AM
Mark Henry   Hi Phil, thanks! but could you keep these ques...   Jun 24 2021, 04:01 PM
DRPHIL914   Hi Phil, thanks! but could you keep these que...   Jun 25 2021, 07:04 AM
- Lo-Fi Version Time is now: 9th July 2025 - 03:24 PM
