DRPHIL914
Jun 9 2021, 07:55 AM
Ok the short story is my motor is out of the car due to lost compression on #3, found loose intake valve seat no damage no injury to lower end. I have been researching head replacement options and rebuild options, but considering rebuilt head could cost close to $1500, and new basic spec heads are close to $2000 or more, although some new castings from AA , Mark Henry and others are doing rebuilds on those , and tis a great option with out breaking the bank, i find myself looking more at the LN RS+, which is the cream of the crop heads for our motors, and i am 90% sure i will be committing to this purchase , i have the opportunity to get set , SO with that said i would be foolish to not consider upgrading the P&C's too.
the LN heads have the larger valves and are ported polished etc , so i think a 2056 is where i want to go because i can do that build by getting new 96's and not have to to into the lower case and change the cam etc. yes i may do that some day but for now i cant afford that, so i am getting these heads and new 96 P&C's
that way i can use the d-jet tuned for the 2056 but go with upgraded FI soon as i can afford it.
first questions that need to be answered is,
1. do i need to change out my push rods? - this should not change the deck height. I could stay 1911 and just add the heads but while it is hear and new P&C are not that expensive, i am not doing Nikki's cant afford that, but 94 and 96's are same and icould have my cylinders sent to them for hone and bored then coating, or just get new-
so what hgave you all done , has anyone done this, leave the stock cam in place and build the 2056 with the new heads and cylinders?/
the also what else do i need?
Thanks for the advice
Phil
also suggestions on the FI issue as well. what kind of expense am i looking at for a upgraded system?
Phil
- i have a 123ignition distributor so i can continue to use it or change but it works great alone or with d-jet.
rfinegan
Jun 9 2021, 08:48 AM
Changing the push rods to Chrome moly has advantages too.
1) You can run ZERO valve lash
2) EZ to adjust
3) Quieter valve train
4) I little more performance with tighter lash (more lift)
5) Optimize Valve Geometry Gross lift and 1/2 lift Reduces were and tear to components
Deck heights can change:
1) Different Cylinders (even with same stroke) brand to brand and even between cylinders for some brands
2) Shimming Registers for desired Compression ratio
3) Heads ( fly cutting heads to squared clean mating or reduce head volume) will changes the required deck height and CR
5) With or without head gaskets ( I did without)
FOR ME: The only way to tell for sure if you need Push Rods is to calculate the geometry when mocking up the components with an adjustable push rod. Then decide what length pushrods are needed and if stock pushrods will do
AS for Heads
We all have our views of what we like and the configurations
With the stock cam 2056 its hard to beat the STOCK 3 bolt intake Porsche fuel injected 2.0L heads
Bigger valves and port work may see fewer returns if a new cam is not selected and reduce port velocity for good street use. Jake did a recommend 2056 build sheet HERE
http://www.914world.com/bbs2/index.php?sho...83920&st=20I not trying to change your decisions or choices. You have a good plan. Just getting you some addition info to let you know what people are doing out there
Bleyseng
Jun 9 2021, 11:21 AM
I went with the Raby 9550 cam that works well with Djet.
96mm pistons which you can have your cylinders bored out and have Keith Black make pistons for or buy a set.
Len Hoffman heads for sure using AA castings all rebuilt with thermal coatings.
2.0 crank and rods
This puts you into a fun 115-120hp engine that runs cool and dependable
DRPHIL914
Jun 9 2021, 11:55 AM
QUOTE(rfinegan @ Jun 9 2021, 10:48 AM)
2) EZ to adjust
2) Shimming Registers for desired Compression ration
3) Heads ( fly cutting heads to square or reduce head volume) will changes the required deck height and CR
AS for Heads
QUOTE(Bleyseng @ Jun 9 2021, 01:21 PM)
2.0 crank and rods
it seems that i would be well served to change the cam to get the most out of a major upgrade like the new RS+ heads and increased cylinder size. just getting the KB pistons and the heads is over or right at my budget at this time, i could probably get that 9550 cam, but really would have to wait 6 months or so to spend the $$ to open the case and swap out the cam and lifters etc. no harm in maintaining for now the stock cam other than as i read in the links robert gave above vrom Jake saying it will make more heat if i interpret that correctly. I didnt have an issue with heat before , head temps were actually really good. shouold be better with new rs heads.
nditiz1
Jun 9 2021, 12:18 PM
When I redid my 2.0, I was only doing a top end. I went cheap on the P&C and got AA ones. Mine was also a 2056 build. I went semi cheap on the heads and had the Len AA specials. They were still pricey at ~$1500. I was able to reuse my stock pushrods (possibly milling a little off them for correct geometry).
If I were in the same situ again, which I was, but had a 6 sitting so I didn't go the 4 route, I would have done things a little different. I would have gotten AA heads again, but just trusted the guidance of both Marks on getting them setup correctly from a competent head machinist. OR put out the bat signal for someone who had decent ones sitting for a build. Len is a wizards with heads, but being more money conscience I would have went cheaper as it is difficult for me to put tons of miles on my car with other aircooled's that need to be driven. So I don't necessarily need them to last 200k.
So AA P&C, AA heads, then you can set whatever deck height you want depending on the heads and cylinders you get. The minor mods can add up as well. Swivel adjusters and solid spacers are nice. Needed...no, but maybe that can fit the budget. Budget conscience you are probably still looking at close to 3k to rebuild a top end for parts and machining things you can't put together at home.
JamesM
Jun 9 2021, 12:42 PM
So, my opinion(s)...
I think you are going to be leaving a lot of power on the table and/or creating a lot of work for yourself by not committing fully to a direction up front. If you are planning on going aftermarket injection in the future make that decision now and build accordingly. Staying with a d-jet cam really limits what you could otherwise do, and going back to change the cam out later is a LOT of work, you are basically building 2 motors.
BUT
Unless you are dumping money on someone to do it for you or are very knowledgeable/capable yourself aftermarket injection can be a LOT of work/steep learning curve and to stack that on top of a freshly built motor may be more of a headache than most want to get into.
SO
Either commit to d-jet or commit to aftermarket injection.
If you commit to d-jet then its 96mm P&Cs + heads + tweaking the d-jet. I personally wouldn't go that route though. At this point I see d-jet as a potential liability on a new motor and having to tweak it to make it compatible with a 2056 just elevates that complexity/liability while leaving a lot of power on the table.
If I were in your shoes, and accepting cost as a factor, this is the approach I would probably take:
1. Find someone dumping a running turnkey 1.7 or 1.8 motor and pick that up on the cheap (because 1.7/1.8s tend to be cheap due to people upgrading)
2. Build an aftermarket injection system on top of the 1.7/1.8 motor. This will give you a chance to tackle the learning curve of aftermarket injection and tuning on a known good/ already broken in/low cost motor. When you are done you will have both a drivable car and a sorted injection system that will transfer over to whatever motor you ultimately want to build. And TBH, I would take a fully dialed in megasquirted 1.7/1.8 over a carbed or poorly tuned d-jet 2.0 anyday.
and then longer term...
3. Build a good 2056 (or even larger) with upgraded cam/compression/heads the way you ultimately want to, not being limited by a d-jet cam, using your existing motor.
Bottom line, figure out the fueling first. You will minimize downtime, save yourself time/money in the long run, and ultimately wind up with a better performing result in the end. Cost for the aftermarket injection can vary wildly depending on how much you want to do yourself vs pay someone else and how much of it you want to be with brand new parts. Realistically could be anywhere from $500-$3000. My current preferred way to build them comes in around ~$1200 in parts but thats getting brand new modern injectors/wideband o2 and a few other nice bits as well.
So maybe $500 for a known running short stroke motor and $1200 for injection bits to get you back on the road and ahead of the game to take whatever motor you want to build without limits.
Mark Henry
Jun 9 2021, 01:06 PM
QUOTE(JamesM @ Jun 9 2021, 02:42 PM)
BUT
SO
Or just run a cheap pair of Weber's till you can afford the FI.
I broke in my 2600cc 78mm stroke 102mm JE/nickies engine on SDS EFI, never worried a bit about the FI or AFR.
colingreene
Jun 9 2021, 04:45 PM
What kind of fuel injection are you planning.
If its fuel injection with dual carb style throttles I would do what mark recommended and run it on carbs till you can do that.
That way you can put a more aggressive cam in it that will make you some more power without having to handicap it for the factory fuel injection.
I have a Web 86A I think. and its extremely drivable and runs out to about 5500. It will rev to 6 but really its not doing you a ton of good.
ottox914
Jun 10 2021, 07:20 PM
Check my sig for details on my 2056 build. I'd think about a running used 1.7/1.8 to stuff in the car for now, and save up for some carbs and a cam. Or start building up an EFI solution. I run SDS on mine, and while some will say its limited in function, I say its got all it needs to get the job done and not alot more to confuse you in your tuning learning curve. If you are going with those sweet heads, get a good cam to match. The OEM cam is a big part of what holds our type 4 engines back.
adolimpio
Jun 10 2021, 08:42 PM
Just finished my 2056.
Started with the original 1.7 case
Added stock 2.0 crank and tins
H-beam rods
JE forged 96mm pistons
Biral lined cylinders
Raby 9550 cam kit with chrome moly push rods, parkerized lifters and swivel feet adjusters.
AA Casting heads from Len Hoffman
FJ67 injectors
Replaced MPS diaphragm and tuned to 12.5 AFR full load and 14 partial load
123 dizzy with vacuum advance
Timing set to 30 degrees at 3500 RPM
Brad Penn break-in oil for cam break in and about 100 miles
Then used Valvoline 20w50 for remainder of break-in
At 500 miles changed oil again, adjusted valves, checked timing and torqued exhaust nuts
Car runs absolutely great. Very smooth and noticeable increase in power.
I'm right up the road in Greenwood so we could meet somewhere if you'd like to check it out.
Mark Henry
Jun 11 2021, 05:45 AM
QUOTE(colingreene @ Jun 9 2021, 06:45 PM)
Depends on the exhaust, with SSI's for heat I'd keep it the stock plenum. I'd play around with a bigger TB, might even custom build a new center section but I'd keep it single TB.
A mild cam like the 86a is still OK with the above and the aftermarket EFI, but anything bigger than say a mild SCAT C-25 will need upgraded valve train.
To run ITB's you really need a header, cam, heads, valve train, etc.
DRPHIL914
Jun 11 2021, 06:46 AM
QUOTE(Mark Henry @ Jun 11 2021, 07:45 AM)
i have SS HE and one of Ben's SS muffer with center twin out tips. I have thought about using the slightly larger throttle body, keeping it otherwise stock single TB intake, some guys here have used that van/bus TB so that might work to add just a bit more air in. With a new heads with new valves and springs etc like the LN RS heads, that would go really nice together. FI wise i have a couple choices but something like what PMB is putting together would be an option too, it can keep a lot of the stock looking stuff but gets rid of the MPS, and old brain, new sensors etc.
will see but i can use a tuned d-jet stock stuff for now, as i have decided for sure i am doing the 2056.
Jun 11 2021, 06:59 AM
QUOTE(DRPHIL914 @ Jun 11 2021, 08:46 AM)
i have SS HE and one of Ben's SS muffer with center twin out tips. I have thought about using the slightly larger throttle body, keeping it otherwise stock single TB intake, some guys here have used that van/bus TB so that might work to add just a bit more air in. With a new heads with new valves and springs, if i do ported gfgggg
I would get you engine back to running as inexpensively as possible and while you are able to drive it, start planning the parts for your engine rebuild. Maybe even buy another core engine or case to build the performance engine.
DRPHIL914
Jun 11 2021, 07:20 AM
QUOTE(mepstein @ Jun 11 2021, 08:59 AM)
i know thats good advice but in order to get it running i have to have new heads, so it opens up the pandoras box of well if i am going to spend $1800-$2000 on basically stock heads might as well spend just a bit more for much better that you dont have to replace on the next level of build. BUT yes its tempting ot just have my heads fixed wit new seats and bold them back on.... but thats not going to be less than about $1000 or so to have them machined, new seats installed and get some new stock valves and springs and put them back on. - Cheapest way to go though.
Jun 11 2021, 07:29 AM
Yes. Spend the $1k now and you will have a good running engine. Then start saving for the performance engine. You will save at least 1k on that engine since you can take the time to plan it out and not be limited or compromised by trying to make some of your current parts work with the future performance parts. There are always deals to be had if you have the time and patience.
cgnj
Jun 11 2021, 02:04 PM
What's the lead time for for HAM to deliver a set of 2.0 clone heads? Does he offer a big valve version of this head?
Your going to have to tear down more than you think. Absolute minimum is pull the crank & rods. The rods should be re-bushed. Crank already out, May as well have it checked.
It's already open, swap the cam.
Why I would spend more of your money.
The cost of re-bushing your rods is so close to the price of new H-beam rods, I'd put them in. I bet you save more than 1Kg of rotating mass (free Hp).
Put the carb cam in now. you're going to do it anyway.
Don't buy used Webers. Empi sells a Drla clone. It's received good reviews on the aircooled forums like Shoptalk. From personal experience, Dell are much easier to tune & are much more streetable. Plus down the road, if a stoker ends up in the picture, Drla 40's can support a 2270.
I built my first 2.0 motor in the early 80's from an ad in Porsche Hot VW. I bought the parts with absolutely no engine experience. My friends still talk how much fun that car was to drive.
Hope this helps
Carlos
Superhawk996
Jun 11 2021, 02:32 PM
mihai914
Jun 11 2021, 03:00 PM
You can also try and find a local shop that knows how to rebuild Harley heads. Chances are the machinist used to own or work on air-cooled VWs at some point.
Then buy the needed hardware from Pelican, AutohausAZ, EMW, etc.
If you don't have broken screws or studs the bill won't be that expensive and it will get you going until you build a better motor.
Bleyseng
Jun 11 2021, 04:19 PM
Yes, Len offers big valve 2.0L heads as I have a set in mine-44x38 and I got the thermal coatings. Wakes up the engine wth the Raby 9550 cam so its a screamer engine. Still have to-get it on a dyno
mb911
Jun 11 2021, 05:47 PM
Just curious what would a total in budget be on an engine proposed by Phil?
JeffBowlsby
Jun 11 2021, 06:00 PM
See what a slippery slope this can be? Not mentioned upgraded brakes, suspension or the host of other possible upgrades to consider.
Why the proverbial mountain out of a molehill, just repair the head and drive/maintain it as it was originally.
930cabman
Jun 11 2021, 06:33 PM
QUOTE(Superhawk996 @ Jun 11 2021, 02:32 PM)
Me too.
Thanks everyone for the input, I may going this route at some point soon. I don't see much with regards to larger displacement (thin bearing surfaces I suspect) or compression (same reason)
If 2056 is the number so be it
Mark Henry
Jun 12 2021, 03:27 AM
QUOTE(930cabman @ Jun 11 2021, 08:33 PM)
Me too.
The only way bigger is a stroked crank, rods, nickies for bigger pistons, etc.
Jeff's right it's a slippery slope, bigger cam add $1k to the valve train and headwork and so on....
adolimpio
Jun 12 2021, 04:47 AM
If you want to get back on the road quick and cheap, and then plan for a more thorough build, I have a pair of freshly rebuilt heads that I bought from Mark Epstein about 2 years ago. I chose to go another direction with my build so I never used them.
One note is that one of the plug ports has a time-sert in it.
I'd like to get what I paid, which was $750.
If you're interested I will send pictures.
DRPHIL914
Jun 23 2021, 06:23 AM
QUOTE(adolimpio @ Jun 12 2021, 06:47 AM)
so just updating this , ive not been on much due to being gone for a week for our daughters wedding and vacation. While i was gone i did decide to send out the heads to Eagle Automotive Machine in Atlanta. They do rebuilds on all air cooled motors, and i was referred to them by local shop.
Turns out my heads are in excellent condition, better they said than most 2.0 that they get in there, and the seats will be done, new exhaust guides etc. he said they look like new and will be finished up this week and sent back to me, i should have them in next week. I am considering doing new P&C's since the heads are off anyway.
@abolimpio , thanks for the offer, looks like i will be reinstalling mine.
since the heads dont need to be milled etc, no fly-cut needed he said, i should be able to re-install with same push rods etc right? Any other advice before getting to that point. - oh and i need one new case stud as one of them came out with the nut on it and they had to cut it , can i get just one? anyone have one? i dont want to remove the ones that stayed in i hate to buy a whole set just to get one,
other question is about spacers/gaskets/shims for between the head and cylinder.
Phil
Jun 23 2021, 08:22 AM
I would keep the same p&c’s if they are good. Minimize the changes to the engine and get back on the road. The increased displacement makes very little difference.
I have a handful of case studs that I removed from a case to make shipping easier. I remember them to be in very good condition. PM or email me your address and I’ll ship them to you.
Jun 23 2021, 08:25 AM
Those heads, crank etc where really nice. I bet you can sell easily if you want.
rfinegan
Jun 23 2021, 08:38 AM
Sounds like you will be back on the road in no time.
With the original cam and valve train I do not see any reason the Stock pushrods can not be reused. Even with a 96 mm big bore kit. Check the deck height for your desired compression and spot check the valve geometry. If all looks good set the valve lash as usual and install and drive
Most will tell you NO head gaskets are needed. But this can change the compression ration calculations. Most of the time it just adds a little bump up, and that is not a bad thing in my opinion
DRPHIL914
Jun 23 2021, 09:09 AM
QUOTE(mepstein @ Jun 23 2021, 10:22 AM)
that would be great!
Bleyseng
Jun 23 2021, 09:22 AM
Don't use gaskets between the heads and cylinders per the VW bulletin. Shim underneath the cylinders to get the right Deck Height.
Mark Henry
Jun 23 2021, 12:25 PM
QUOTE(Bleyseng @ Jun 23 2021, 11:22 AM)
Do the math!
CB performance and others have an engine calculator.
Mark Henry
dp
Jun 23 2021, 12:53 PM
QUOTE(Mark Henry @ Jun 23 2021, 02:25 PM)
Do the math!
Mark Henry - Pertinent question to this thread. I’m guessing the switch from 94mm p&c’s to 96’s only adds about 5hp. Your thoughts?
Mark Henry
Jun 23 2021, 12:54 PM
Maybe, but I doubt if half that much.
HP increases are the sum of the parts.
On the 996/7 engines I build up from 3.6 to 4.0 I'd be surprised if it's much over 20 extra HP.
Mark Henry
Jun 23 2021, 01:14 PM
BTW AA only just shipped my skid of parts including several sets of 914 2.0 heads, both AMC and AA flavors, on Monday,
But at least they are on the way finally.
Jun 23 2021, 01:21 PM
QUOTE(Mark Henry @ Jun 23 2021, 02:54 PM)
That’s what I thought but wanted to confirm with a real engine builder.
DRPHIL914
Jun 23 2021, 02:24 PM
QUOTE(mepstein @ Jun 23 2021, 03:21 PM)
so probably for this refresh staying stock, wondering if i should at least put new rings on? compression before this was 135,135, 125 130 i think. then it went to 0 with that open valve due to seat being loose but , new rings a good idea?
DRPHIL914
Jun 23 2021, 02:40 PM
Do the math!
i saw that posted somewhere and read about doing that , if needed, under the cylinder not between the cylinder and head- these heads did have shim between cylinder and head and i didn’t measure them as they were stuck on the heads, and i don’t think they eagle machine did either, but they are gone now, he said the heads are clean, good shape, didn’t need to be fly cut- so does that mean clean ans level surface ? when you say measure o assume you mean deck height, and checking for clearance - so once heads are back, mount them up and make sure valves are not interfering with piston when at TDC.
if i had the known thickness of those gaskets i’d have a better idea about what we need to be replacing. wonder what the history is ans why they did that years ago. car only ha 60k miles on it now, about 38k or so when i bought it 12 years ago and previous records which there is a stack of don’t show any motor work, but there is about a 20 year span of almost nothing.
so could be someone at some time did an upper end refresh? did they use gaskets there when new bacon in 1975 ? did that bulletin came out much later ?
Jun 23 2021, 04:47 PM
Porsche moved from head gaskets 3.0 to base shims on the 3.2 but I have no idea what they do now or what the early engines had. Yes wouldn’t be surprised if they went back and forth a couple times in their history.
Mark Henry
Jun 24 2021, 05:26 AM
QUOTE(mepstein @ Jun 23 2021, 06:47 PM)
No, the /6 has always used base shims to adjust CR, this style of head gasket (different from VW) dosen't effect deck height.
Mark Henry
Jun 24 2021, 05:38 AM
You have to measure head cc, if HAM heads cc is stamped on the head. You have to buy or make a plate and use a syringe to measure the head cc. Measure deck height and then plug all your numbers into the engine calculator.
Shims come in .010" increments, play with the calculator till you find your CR and shims size.
Many threads on how to do this.
DRPHIL914
Jun 24 2021, 06:37 AM
QUOTE(Mark Henry @ Jun 24 2021, 07:38 AM)
roger that. will do some research on this, and once i get my heads back from the shop, will go to work on getting these measurements done and figure out how much gasket is necessary.
so- no gaskets at head, measure, figure deck height CC etc, get gasket if needed, for placement at base of cylinders, etc etc.
thanks for the advice etc, kind of helped me from doing things here that are not needed unless i do a full rebuild, which will happen at some point, but right now, just getting this running and back on the road, shouldnt be too hard of a task.
its giving me a chance since the motor is out, to address the leak at the oil pump seal and the push rod tubes. moving on...... - original heads rebuilt, but i will be looking close at which rebuild i would like to do going forward.
Phil
Jun 24 2021, 07:02 AM
That's the nice thing about the LN kits. He has combos that have been tested and proven vs throwing a bunch of nice parts at a build and hoping it all works. Sort of like when a professional looks something over and charges $200 for 5 minutes. You are not really paying for the 5 minutes, you are paying for the years of education that allow him to make a determination in 5 minutes.
Mark Henry
Jun 24 2021, 04:01 PM
Hi Phil, thanks! but could you keep these questions in the garage.
Mark, would you suggest if i have my stock but newly rebuilt heads and original cylinders etc , should i at least place new rings on pistons while they are all at this point, i will have to pull the cylinders to shim probably , and if so what brand, type for a stock 94mm 2.0 would you use?
- machine shop said he thoguht the cylinder gaskets that came off those were only .010's, but i dont know for sure so it will all have to be measured as you suggested to make sure.
PHil- many thanks.!!!
I'd always at minimum measure the jugs and slugs, hone and re-ring, I've done it many times, I have a set on the shelf. The jugs must be in spec, the ring lands have to be good etc.
Honestly I've never had an issue with Grants or Deves rings, Goetze can take 1K to break in.
Stock VR gasket set base shims are about .008 you can use up to 3 shims per jug. You can get shims in bigger sizes from T4store, EMW, AA, etc.
DRPHIL914
Jun 25 2021, 07:04 AM
QUOTE(Mark Henry @ Jun 24 2021, 06:01 PM)
sure
good to know, been , looking etc
BTW for all persons, lots of stuff is either on back order or not available for months,
lots of suppliers are backed up and out of stock on parts and supplies.
-thanks for t he info on the spacers and shims,
