> 2056 build advice requested from those that have been there, June 23 update: original heads rebuilt and will be reinstalled with 96's, will save up for the full upgraded LN
DRPHIL914
post Jun 9 2021, 07:55 AM
Dr. Phil
Ok the short story is my motor is out of the car due to lost compression on #3, found loose intake valve seat no damage no injury to lower end. I have been researching head replacement options and rebuild options, but considering rebuilt head could cost close to $1500, and new basic spec heads are close to $2000 or more, although some new castings from AA , Mark Henry and others are doing rebuilds on those , and tis a great option with out breaking the bank, i find myself looking more at the LN RS+, which is the cream of the crop heads for our motors, and i am 90% sure i will be committing to this purchase , i have the opportunity to get set , SO with that said i would be foolish to not consider upgrading the P&C's too.
the LN heads have the larger valves and are ported polished etc , so i think a 2056 is where i want to go because i can do that build by getting new 96's and not have to to into the lower case and change the cam etc. yes i may do that some day but for now i cant afford that, so i am getting these heads and new 96 P&C's
that way i can use the d-jet tuned for the 2056 but go with upgraded FI soon as i can afford it.
first questions that need to be answered is,
1. do i need to change out my push rods? - this should not change the deck height. I could stay 1911 and just add the heads but while it is hear and new P&C are not that expensive, i am not doing Nikki's cant afford that, but 94 and 96's are same and icould have my cylinders sent to them for hone and bored then coating, or just get new-
so what hgave you all done , has anyone done this, leave the stock cam in place and build the 2056 with the new heads and cylinders?/
the also what else do i need?
Thanks for the advice
Phil
also suggestions on the FI issue as well. what kind of expense am i looking at for a upgraded system?
Phil
- i have a 123ignition distributor so i can continue to use it or change but it works great alone or with d-jet.
post Jun 11 2021, 07:29 AM
914-6 GT in waiting
Yes. Spend the $1k now and you will have a good running engine. Then start saving for the performance engine. You will save at least 1k on that engine since you can take the time to plan it out and not be limited or compromised by trying to make some of your current parts work with the future performance parts. There are always deals to be had if you have the time and patience.
DRPHIL914   2056 build advice requested from those that have been there   Jun 9 2021, 07:55 AM
rfinegan   Changing the push rods to Chrome moly has advantag...   Jun 9 2021, 08:48 AM
Bleyseng   I went with the Raby 9550 cam that works well with...   Jun 9 2021, 11:21 AM
DRPHIL914   Changing the push rods to Chrome moly has advanta...   Jun 9 2021, 11:55 AM
nditiz1   When I redid my 2.0, I was only doing a top end. ...   Jun 9 2021, 12:18 PM
JamesM   So, my opinion(s)... I think you are going to be...   Jun 9 2021, 12:42 PM
Mark Henry   So, my opinion(s)... I think you are going to b...   Jun 9 2021, 01:06 PM
colingreene   What kind of fuel injection are you planning. If ...   Jun 9 2021, 04:45 PM
Mark Henry   What kind of fuel injection are you planning. If...   Jun 11 2021, 05:45 AM
DRPHIL914   What kind of fuel injection are you planning. I...   Jun 11 2021, 06:46 AM
mepstein   [quote name='Mark Henry' post='2922627' date='Jun...   Jun 11 2021, 06:59 AM
DRPHIL914   [quote name='Mark Henry' post='2922627' date='Ju...   Jun 11 2021, 07:20 AM
ottox914   Check my sig for details on my 2056 build. I...   Jun 10 2021, 07:20 PM
adolimpio   Just finished my 2056. Started with the original...   Jun 10 2021, 08:42 PM
mepstein   Yes. Spend the $1k now and you will have a go...   Jun 11 2021, 07:29 AM
cgnj   What's the lead time for for HAM to deliver a ...   Jun 11 2021, 02:04 PM
Superhawk996   :popcorn:   Jun 11 2021, 02:32 PM
930cabman   :popcorn: Me too. Thanks everyone for the inpu...   Jun 11 2021, 06:33 PM
Mark Henry   :popcorn: Me too. Thanks everyone for the inp...   Jun 12 2021, 03:27 AM
mihai914   You can also try and find a local shop that knows ...   Jun 11 2021, 03:00 PM
Bleyseng   Yes, Len offers big valve 2.0L heads as I have a s...   Jun 11 2021, 04:19 PM
mb911   Just curious what would a total in budget be on an...   Jun 11 2021, 05:47 PM
JeffBowlsby   See what a slippery slope this can be? Not mentio...   Jun 11 2021, 06:00 PM
adolimpio   If you want to get back on the road quick and chea...   Jun 12 2021, 04:47 AM
DRPHIL914   If you want to get back on the road quick and che...   Jun 23 2021, 06:23 AM
mepstein   If you want to get back on the road quick and che...   Jun 23 2021, 08:25 AM
mepstein   I would keep the same p&c’s if they are good...   Jun 23 2021, 08:22 AM
DRPHIL914   I would keep the same p&c’s if they are goo...   Jun 23 2021, 09:09 AM
rfinegan   Sounds like you will be back on the road in no tim...   Jun 23 2021, 08:38 AM
Bleyseng   Don't use gaskets between the heads and cylind...   Jun 23 2021, 09:22 AM
Mark Henry   Don't use gaskets between the heads and cylin...   Jun 23 2021, 12:25 PM
DRPHIL914   Don't use gaskets between the heads and cyli...   Jun 23 2021, 02:40 PM
Mark Henry   dp   Jun 23 2021, 12:25 PM
mepstein   Don't use gaskets between the heads and cyli...   Jun 23 2021, 12:53 PM
Mark Henry   Maybe, but I doubt if half that much. HP increase...   Jun 23 2021, 12:54 PM
mepstein   Maybe, but I doubt if half that much. HP increas...   Jun 23 2021, 01:21 PM
DRPHIL914   Maybe, but I doubt if half that much. HP increa...   Jun 23 2021, 02:24 PM
Mark Henry   BTW AA only just shipped my skid of parts includin...   Jun 23 2021, 01:14 PM
mepstein   Porsche moved from head gaskets 3.0 to base shims ...   Jun 23 2021, 04:47 PM
Mark Henry   Porsche moved from head gaskets 3.0 to base shims...   Jun 24 2021, 05:26 AM
Mark Henry   You have to measure head cc, if HAM heads cc is st...   Jun 24 2021, 05:38 AM
DRPHIL914   You have to measure head cc, if HAM heads cc is s...   Jun 24 2021, 06:37 AM
mepstein   That's the nice thing about the LN kits. He ha...   Jun 24 2021, 07:02 AM
Mark Henry   Hi Phil, thanks! but could you keep these ques...   Jun 24 2021, 04:01 PM
DRPHIL914   Hi Phil, thanks! but could you keep these que...   Jun 25 2021, 07:04 AM
- Lo-Fi Version Time is now: 9th July 2025 - 03:46 PM
