Hesitation while Cruising, '74 2.0l D-Jet |
Nogoodwithusernames |
Jun 14 2021, 04:44 PM
Member Group: Members Posts: 239 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
Had the 914 out a couple times this weekend and noticed some hesitation while at light throttle cruising, say at like 25-30mph in 3rd.
I just recently did a valve adjustment and checked timing per the manual, had to clean up the points a little bit as one side had a little bit of a 'tit' starting to grow. Other than the hesitation it seems to be running well still, maybe a bit on the warmer side compared to what it used to be? (Also first time out this summer, ran it a few times this spring when it was nice and cool) But it has good power, and no audible changes in tone. What should I be checking first? Timing looked like it was right on the mark with vac line off and at about 3-3.5k rpm so I don't *think* that's the issue. |
gonzo54 |
Jun 14 2021, 06:10 PM
Orange Crush Group: Members Posts: 226 Joined: 10-May 19 From: Seal Beach, CA Member No.: 23,112 Region Association: Southern California |
I agree, Throttle Position Sensor was my hesitation and bucking problem. I cleaned it and it came back so I replaced it with used sensor and so far it is running much better. Long term plan is a new board from 914 Rubber
Lo-Fi Version | Time is now: 10th June 2024 - 06:58 AM |
