Nogoodwithusernames |
Member ![]() ![]() Group: Members Posts: 239 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None ![]() |
Had the 914 out a couple times this weekend and noticed some hesitation while at light throttle cruising, say at like 25-30mph in 3rd.
I just recently did a valve adjustment and checked timing per the manual, had to clean up the points a little bit as one side had a little bit of a 'tit' starting to grow. Other than the hesitation it seems to be running well still, maybe a bit on the warmer side compared to what it used to be? (Also first time out this summer, ran it a few times this spring when it was nice and cool) But it has good power, and no audible changes in tone. What should I be checking first? Timing looked like it was right on the mark with vac line off and at about 3-3.5k rpm so I don't *think* that's the issue. |
Thanks for the tips, I will check on the TPS. That would be a nice easy fix for sure.
Isn't 3rd recommended in the manual for that speed? I know my VW is, and it's only got 4 gears. *edit for clarity* my 914 has 5 gears, my VW has 4 gears and cruises 25mph in 3rd gear just fine. Thus thinking out loud shouldn't the 914 also be able to do the same since it has a bigger motor AND more gears? Cheers to all for the replies! (IMG:style_emoticons/default/beerchug.gif) I'll report back with results either way. |
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 3,956 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
Thanks for the tips, I will check on the TPS. That would be a nice easy fix for sure. Isn't 3rd recommended in the manual for that speed? I know my VW is, and it's only got 4 gears. *edit for clarity* my 914 has 5 gears, my VW has 4 gears and cruises 25mph in 3rd gear just fine. Thus thinking out loud shouldn't the 914 also be able to do the same since it has a bigger motor AND more gears? Cheers to all for the replies! (IMG:style_emoticons/default/beerchug.gif) I'll report back with results either way. It can do 25mph in 3rd gear, but if you're at ~2800rpm or below you should be downshifting or you're lugging the engine. |
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,036 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
Thanks for the tips, I will check on the TPS. That would be a nice easy fix for sure. Isn't 3rd recommended in the manual for that speed? I know my VW is, and it's only got 4 gears. *edit for clarity* my 914 has 5 gears, my VW has 4 gears and cruises 25mph in 3rd gear just fine. Thus thinking out loud shouldn't the 914 also be able to do the same since it has a bigger motor AND more gears? Cheers to all for the replies! (IMG:style_emoticons/default/beerchug.gif) I'll report back with results either way. It can do 25mph in 3rd gear, but if you're at ~2800rpm or below you should be downshifting or you're lugging the engine. That’s my point exactly. You’ll prolong engine life by making a habit of cruising at 3000 rpm or above. |
Lo-Fi Version | Time is now: 10th June 2024 - 12:44 PM |
