Wiper motor test |
Wiper motor test |
partwerks |
Jun 15 2021, 07:01 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
914Sixer |
Jun 15 2021, 08:47 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
NOT the same as headlight motor. Only two reasons for motor not to work. Bad switch or arms frozen in shaft. Usually the latter. Put battery in car and turn on switch. It works or it doesn't.
partwerks |
Jun 15 2021, 08:58 PM
NOT the same as headlight motor. Only two reasons for motor not to work. Bad switch or arms frozen in shaft. Usually the latter. Put battery in car and turn on switch. It works or it doesn't. It's out of that thing in the picture. No other way to test it outside of the car? |
bdstone914 |
Jun 15 2021, 09:50 PM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
NOT the same as headlight motor. Only two reasons for motor not to work. Bad switch or arms frozen in shaft. Usually the latter. Put battery in car and turn on switch. It works or it doesn't. It's out of that thing in the picture. No other way to test it outside of the car? Yes you can test it out of the car. Hook up a ground wire and positive wire. |
partwerks |
Jun 15 2021, 09:54 PM
NOT the same as headlight motor. Only two reasons for motor not to work. Bad switch or arms frozen in shaft. Usually the latter. Put battery in car and turn on switch. It works or it doesn't. It's out of that thing in the picture. No other way to test it outside of the car? Yes you can test it out of the car. Hook up a ground wire and positive wire. I hooked the ground up to the brown wire, and the positive to where the two red wire go? Either I hooked it up wrong, or doesn't work? IDK. Or is it like the headlight motor where you have to have one on the red, and one on either the gray or green wire? |
bdstone914 |
Jun 16 2021, 03:56 AM
NOT the same as headlight motor. Only two reasons for motor not to work. Bad switch or arms frozen in shaft. Usually the latter. Put battery in car and turn on switch. It works or it doesn't. It's out of that thing in the picture. No other way to test it outside of the car? Yes you can test it out of the car. Hook up a ground wire and positive wire. I hooked the ground up to the brown wire, and the positive to where the two red wire go? Either I hooked it up wrong, or doesn't work? IDK. Or is it like the headlight motor where you have to have one on the red, and one on either the gray or green wire? I dont remember the wiring but connect the positive to each of the individual wires and combinations on the positive terminals. |
Lo-Fi Version | Time is now: 7th June 2024 - 11:16 AM |
