QUOTE(bdstone914 @ Jun 15 2021, 07:50 PM)
QUOTE(partwerks @ Jun 15 2021, 07:58 PM)
QUOTE(914Sixer @ Jun 15 2021, 06:47 PM)
NOT the same as headlight motor. Only two reasons for motor not to work. Bad switch or arms frozen in shaft. Usually the latter. Put battery in car and turn on switch. It works or it doesn't.
It's out of that thing in the picture.
No other way to test it outside of the car?
Yes you can test it out of the car. Hook up a ground wire and positive wire.
I hooked the ground up to the brown wire, and the positive to where the two red wire go?
Either I hooked it up wrong, or doesn't work? IDK.
Or is it like the headlight motor where you have to have one on the red, and one on either the gray or green wire?
