Hesitation while Cruising, '74 2.0l D-Jet |
Nogoodwithusernames |
Jun 14 2021, 04:44 PM
Member Group: Members Posts: 239 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
Had the 914 out a couple times this weekend and noticed some hesitation while at light throttle cruising, say at like 25-30mph in 3rd.
I just recently did a valve adjustment and checked timing per the manual, had to clean up the points a little bit as one side had a little bit of a 'tit' starting to grow. Other than the hesitation it seems to be running well still, maybe a bit on the warmer side compared to what it used to be? (Also first time out this summer, ran it a few times this spring when it was nice and cool) But it has good power, and no audible changes in tone. What should I be checking first? Timing looked like it was right on the mark with vac line off and at about 3-3.5k rpm so I don't *think* that's the issue. |
DRPHIL914 |
Jun 17 2021, 01:23 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
mine had that bucking as well for years, thought the TPS board would be “worn” but the marks on it were just oxidation on the trail of where the feelers ran. cleaned with an eraser spotlessly like yours and bam, no bucking at all. i will bet you will have a nice smooth running motor now.
Lo-Fi Version | Time is now: 10th June 2024 - 09:33 AM |
