Hesitation while Cruising, '74 2.0l D-Jet |
Nogoodwithusernames |
Jun 14 2021, 04:44 PM
Member Group: Members Posts: 239 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
Had the 914 out a couple times this weekend and noticed some hesitation while at light throttle cruising, say at like 25-30mph in 3rd.
I just recently did a valve adjustment and checked timing per the manual, had to clean up the points a little bit as one side had a little bit of a 'tit' starting to grow. Other than the hesitation it seems to be running well still, maybe a bit on the warmer side compared to what it used to be? (Also first time out this summer, ran it a few times this spring when it was nice and cool) But it has good power, and no audible changes in tone. What should I be checking first? Timing looked like it was right on the mark with vac line off and at about 3-3.5k rpm so I don't *think* that's the issue. |
windforfun |
Jun 17 2021, 01:04 PM
Senior Member Group: Members Posts: 1,838 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Is that a new TPS? Why are the slots in the mounting screw heads all messed up?
Jun 17 2021, 01:14 PM
windforfun |
Jun 17 2021, 01:32 PM
Is that a new TPS? Why are the slots in the mounting screw heads all messed up? No this was my existing TPS, just cleaned the traces of the board. Is the rotational alignment the same as when you pulled it out? |
Lo-Fi Version | Time is now: 10th June 2024 - 03:23 AM |
