Fuel pump fuse, Fues keeps blowing. |
lexus914 |
Jun 21 2021, 08:05 PM
Newbie Group: Members Posts: 4 Joined: 9-May 15 From: fishers,in. Member No.: 18,716 Region Association: MidAtlantic Region |
I have ‘73 914 2L with factory FI. My fuel pump fuse all of a sudden started to blow.
I checked my AAR and it functions as it should. I checked the lead and is does not appear to be compromised . I checked the resistance and it is reading 13. What else do I need to check? |
bdstone914 |
Jun 22 2021, 06:41 PM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have ‘73 914 2L with factory FI. My fuel pump fuse all of a sudden started to blow. I checked my AAR and it functions as it should. I checked the lead and is does not appear to be compromised . I checked the resistance and it is reading 13. What else do I need to check? If you have a battery charger run the pump off of it and see how much current it pulls. I think it should be around 5 amps. If it is ok check for shorts to ground. Swap the relay with a headlight relay. Make sure all connections are corrosion free. |
Lo-Fi Version | Time is now: 7th June 2024 - 10:54 PM |
