DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,829 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
Ok the short story is my motor is out of the car due to lost compression on #3, found loose intake valve seat no damage no injury to lower end. I have been researching head replacement options and rebuild options, but considering rebuilt head could cost close to $1500, and new basic spec heads are close to $2000 or more, although some new castings from AA , Mark Henry and others are doing rebuilds on those , and tis a great option with out breaking the bank, i find myself looking more at the LN RS+, which is the cream of the crop heads for our motors, and i am 90% sure i will be committing to this purchase , i have the opportunity to get set , SO with that said i would be foolish to not consider upgrading the P&C's too.
the LN heads have the larger valves and are ported polished etc , so i think a 2056 is where i want to go because i can do that build by getting new 96's and not have to to into the lower case and change the cam etc. yes i may do that some day but for now i cant afford that, so i am getting these heads and new 96 P&C's that way i can use the d-jet tuned for the 2056 but go with upgraded FI soon as i can afford it. first questions that need to be answered is, 1. do i need to change out my push rods? - this should not change the deck height. I could stay 1911 and just add the heads but while it is hear and new P&C are not that expensive, i am not doing Nikki's cant afford that, but 94 and 96's are same and icould have my cylinders sent to them for hone and bored then coating, or just get new- so what hgave you all done , has anyone done this, leave the stock cam in place and build the 2056 with the new heads and cylinders?/ the also what else do i need? Thanks for the advice Phil - also suggestions on the FI issue as well. what kind of expense am i looking at for a upgraded system? Phil - i have a 123ignition distributor so i can continue to use it or change but it works great alone or with d-jet. |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Don't use gaskets between the heads and cylinders per the VW bulletin. Shim underneath the cylinders to get the right Deck Height.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
dp
Mark Henry |
Maybe, but I doubt if half that much.
HP increases are the sum of the parts. On the 996/7 engines I build up from 3.6 to 4.0 I'd be surprised if it's much over 20 extra HP. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,958 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Maybe, but I doubt if half that much. HP increases are the sum of the parts. On the 996/7 engines I build up from 3.6 to 4.0 I'd be surprised if it's much over 20 extra HP. That’s what I thought but wanted to confirm with a real engine builder. (IMG:style_emoticons/default/beerchug.gif) |
DRPHIL914 |
Maybe, but I doubt if half that much. HP increases are the sum of the parts. On the 996/7 engines I build up from 3.6 to 4.0 I'd be surprised if it's much over 20 extra HP. That’s what I thought but wanted to confirm with a real engine builder. (IMG:style_emoticons/default/beerchug.gif) so probably for this refresh staying stock, wondering if i should at least put new rings on? compression before this was 135,135, 125 130 i think. then it went to 0 with that open valve due to seat being loose but , new rings a good idea? |
Lo-Fi Version | Time is now: 9th July 2025 - 04:22 PM |
