DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,829 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
Ok the short story is my motor is out of the car due to lost compression on #3, found loose intake valve seat no damage no injury to lower end. I have been researching head replacement options and rebuild options, but considering rebuilt head could cost close to $1500, and new basic spec heads are close to $2000 or more, although some new castings from AA , Mark Henry and others are doing rebuilds on those , and tis a great option with out breaking the bank, i find myself looking more at the LN RS+, which is the cream of the crop heads for our motors, and i am 90% sure i will be committing to this purchase , i have the opportunity to get set , SO with that said i would be foolish to not consider upgrading the P&C's too.
the LN heads have the larger valves and are ported polished etc , so i think a 2056 is where i want to go because i can do that build by getting new 96's and not have to to into the lower case and change the cam etc. yes i may do that some day but for now i cant afford that, so i am getting these heads and new 96 P&C's that way i can use the d-jet tuned for the 2056 but go with upgraded FI soon as i can afford it. first questions that need to be answered is, 1. do i need to change out my push rods? - this should not change the deck height. I could stay 1911 and just add the heads but while it is hear and new P&C are not that expensive, i am not doing Nikki's cant afford that, but 94 and 96's are same and icould have my cylinders sent to them for hone and bored then coating, or just get new- so what hgave you all done , has anyone done this, leave the stock cam in place and build the 2056 with the new heads and cylinders?/ the also what else do i need? Thanks for the advice Phil - also suggestions on the FI issue as well. what kind of expense am i looking at for a upgraded system? Phil - i have a 123ignition distributor so i can continue to use it or change but it works great alone or with d-jet. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Hi Phil, thanks! but could you keep these questions in the garage.
QUOTE Mark, would you suggest if i have my stock but newly rebuilt heads and original cylinders etc , should i at least place new rings on pistons while they are all at this point, i will have to pull the cylinders to shim probably , and if so what brand, type for a stock 94mm 2.0 would you use? - machine shop said he thoguht the cylinder gaskets that came off those were only .010's, but i dont know for sure so it will all have to be measured as you suggested to make sure. PHil- many thanks.!!! I'd always at minimum measure the jugs and slugs, hone and re-ring, I've done it many times, I have a set on the shelf. The jugs must be in spec, the ring lands have to be good etc. Honestly I've never had an issue with Grants or Deves rings, Goetze can take 1K to break in. Stock VR gasket set base shims are about .008 you can use up to 3 shims per jug. You can get shims in bigger sizes from T4store, EMW, AA, etc. |
DRPHIL914 |
Hi Phil, thanks! but could you keep these questions in the garage. sure (IMG:style_emoticons/default/smile.gif) QUOTE Mark, would you suggest if i have my stock but newly rebuilt heads and original cylinders etc , should i at least place new rings on pistons while they are all at this point, i will have to pull the cylinders to shim probably , and if so what brand, type for a stock 94mm 2.0 would you use? - machine shop said he thoguht the cylinder gaskets that came off those were only .010's, but i dont know for sure so it will all have to be measured as you suggested to make sure. PHil- many thanks.!!! I'd always at minimum measure the jugs and slugs, hone and re-ring, I've done it many times, I have a set on the shelf. The jugs must be in spec, the ring lands have to be good etc. Honestly I've never had an issue with Grants or Deves rings, Goetze can take 1K to break in. Stock VR gasket set base shims are about .008 you can use up to 3 shims per jug. You can get shims in bigger sizes from T4store, EMW, AA, etc. good to know, been , looking etc BTW for all persons, lots of stuff is either on back order or not available for months, lots of suppliers are backed up and out of stock on parts and supplies. -thanks for t he info on the spacers and shims, |
Lo-Fi Version | Time is now: 9th July 2025 - 03:22 PM |
