Show me your fire extinguishers and where/how you mounted, I need to add one to my 914 - need some inspiration |
DC_neun_vierzehn |
Jun 3 2021, 03:11 PM
Member Group: Members Posts: 393 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
I'm reading too many horror stories online of engine compartment fires on 914s. It's probably time I added a fire extinguisher. I have a '73 2.0 and it has the center console. Thus, not a lot of spots to mount it w/o sacrificing room.
I'm wondering if there's one small enough to fit behind the driver's seat. I'm 6'1" so my seat is all the way back, but I could probably slide it up a notch or two if it meant that I would have an extinguisher handy. The other thought I had was mounting it in the front trunk. Obviously, not as handy, but only 5 extra seconds away from pulling it out. Thanks in advance. |
pete000 |
Jun 5 2021, 08:08 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Here is one I made from some simple tubing and bending for my 914-6. I later had it powder coated black. No drilling needed by using the stock seat mounting points. I also made one for my 74 which has the adjustable seat similarly.
Attached thumbnail(s) |
913B |
Jun 5 2021, 11:24 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Here is one I made from some simple tubing and bending for my 914-6. I later had it powder coated black. No drilling needed by using the stock seat mounting points. I also made one for my 74 which has the adjustable seat similarly. @pete000 Would you be so kind if you could show more details of the mount? I need to make one for my 71. Thank you Sir! |
pete000 |
Jun 25 2021, 02:52 PM
Here is one I made from some simple tubing and bending for my 914-6. I later had it powder coated black. No drilling needed by using the stock seat mounting points. I also made one for my 74 which has the adjustable seat similarly. @pete000 Would you be so kind if you could show more details of the mount? I need to make one for my 71. Thank you Sir! @913B Just took some mild steel tubing and flattened the ends cut them at the correct angle to line up with the holes in the extinguisher bracket. I did make a cardboard mock up to get the angles and depth just right. You could accomplish the same with flat stock metal or alloy, but I found the tubing was nice ant stiff so no movement what so ever. |
Lo-Fi Version | Time is now: 8th June 2024 - 03:54 AM |
