aircooledboy |
Sweet Pea's 1st ride in daddy's "vroom -vroom" ![]() ![]() ![]() Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest ![]() |
Well, pulled the trans yesterday. Went very well, thanks for the pointers. (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif)
Hi-evah, something is just not right with the clutch assembly. When I first mated the trans back to the engine in august, I noticed there was no free travel in the clutch fork. I even pulled it back apart to male sure noting had gotten caught. Once put back together, I had to tighten the clutch cable to get the fork off the back of the opening int the bell housing, or the fork would chatter against the housing with the clutch out. Well when I took it apart yesterday, I find that the top of the pressure plate is hitting the fork, which ground a groove into the fork. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) Attached image(s) ![]() |
aircooledboy |
Here you can see the part of the pressure plate that is hitting the fork. It it tough to tell in this lower res. picture, but the bottom of the plate in the picture is much more worn from the contact, and the top edge doesn't appear to have been touching the fork at all.
Lo-Fi Version | Time is now: 10th June 2024 - 11:13 PM |
