Something not right w/ clutch, Help needed from V8 guys again |
aircooledboy |
Jan 1 2005, 01:46 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
Well, pulled the trans yesterday. Went very well, thanks for the pointers. (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif)
Hi-evah, something is just not right with the clutch assembly. When I first mated the trans back to the engine in august, I noticed there was no free travel in the clutch fork. I even pulled it back apart to male sure noting had gotten caught. Once put back together, I had to tighten the clutch cable to get the fork off the back of the opening int the bell housing, or the fork would chatter against the housing with the clutch out. Well when I took it apart yesterday, I find that the top of the pressure plate is hitting the fork, which ground a groove into the fork. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) Attached image(s) |
aircooledboy |
Jan 1 2005, 01:57 PM
I have heard talk about using washers as spacers on the pivot ball, but I'm not sure how that would improve my situation. It seems to me I need more clearance, not less. After I took off the TO today I noticed that the cover on the main shaft seal is held with bolts instead of nuts on a stud(might even be nuts welded onto a stud). I wondered if maybe that is where I am loosing the 1/8 of an inch or so that I need.
Lastly, I am going to go ahead and replace the clutch, since it chattered anyway, and now seeing the way the pressure plate was unevenly contacting the fork, I suspect it is warped. What are these clutch parts, and where do I get new ones (besides from Renegade)? The pressure plate has "KEP" on it, but no numbers. How do I know what to ask for (as far as the plate, disk and T.O.)? Attached image(s) |
Lo-Fi Version | Time is now: 10th June 2024 - 11:09 PM |
