Something not right w/ clutch, Help needed from V8 guys again |
aircooledboy |
Jan 1 2005, 01:46 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
Well, pulled the trans yesterday. Went very well, thanks for the pointers. (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif)
Hi-evah, something is just not right with the clutch assembly. When I first mated the trans back to the engine in august, I noticed there was no free travel in the clutch fork. I even pulled it back apart to male sure noting had gotten caught. Once put back together, I had to tighten the clutch cable to get the fork off the back of the opening int the bell housing, or the fork would chatter against the housing with the clutch out. Well when I took it apart yesterday, I find that the top of the pressure plate is hitting the fork, which ground a groove into the fork. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) Attached image(s) |
rich brennick |
Jan 1 2005, 04:00 PM
Forever Newbie Group: Members Posts: 76 Joined: 23-July 03 From: Mid-Michigan Member No.: 942 |
Chris,
Do you have a fax available? I can send you the official KEP "How to properly set up a Kennedy 9" clutch into a 914, 912, & '66-'69 911 Porsche transaxle." If not, here are the highlights: #2... Replace the two studs for the guide tube with the two small bolts provided... This will allow for more release bearing travel. Use a locktite and tighten securely. #3. Unthread the pivot ball...remove washer from under it, this will also allow more bearing release travel... #4... the end of the clutch release lever on the transaxle should have almost a half of an inch travel to allow for future adjustment. This freeplay will reduce as the disc wears. #5. If the freeplay exceeds a half inch or is under a quarter inch, you may bend the release arm, but usually it is not necessary. It is made of malleable iron so it can be bent hot or cold... #7 The porsche clutch cable needs to have at least 1 1/2" of travel... Hope this helps, Rich |
Lo-Fi Version | Time is now: 11th June 2024 - 03:13 AM |
