| campbellcj |
Jul 11 2021, 03:38 PM
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,676 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California
Hey everyone - I have a problem I've been meaning to get resolved for some time but I'm not sure where things went wrong. Once I reinstalled the lights in my car after they had been out for several years of dedicated track use, the turn signals aren't working right; however, the puzzling part is the hazards blink fine, parking lights work, and the lever-actuated 'park mode' also works on both sides. This leads me to believe I pretty much connected things right and the stalk switch seems OK too, but obviously I went astray somewhere.
It's been a while but IIRC I did already try swapping in a different flasher relay to no avail. Also FWIW the stalk switch and dash wiring had not been removed/reinstalled, only the actual lamps up-front and their fuses. So the interior wiring should be basically unmolested (by me at least). This car is painful to work inside due to full rollcage and immovable seats. If any of you has seen this specific fault before I would massively appreciate a tip before I start poking around at every single wire (again)! Thanks! |
| bbrock |
Jul 18 2021, 01:01 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
Also, make sure your grounds are all good. After finishing my bare metal resto, I had a strange problem with the right front turn signal. Turned out that the signal bucket bracket was not piercing through the bedliner I sprayed for undercoating so that bucket was not properly grounded. Instead, it was grounding through the other turn signal bulb cause weird light behavior. Once I tightened the bracket enough to make good contact with the chassis metal, everything worked perfectly.
Not saying that is your problem, just pointing out one of those weird things that can be hard to track down. |
campbellcj Turn signal troubleshooting Jul 11 2021, 03:38 PM
914-Kazoo
Hey everyone - I have a problem I've been mea... Jul 17 2021, 07:12 PM
campbellcj Thank you! I plan to put some time into this l... Jul 18 2021, 12:40 PM
mlindner Chris my 914 was apart for 25 years, everything wo... Jul 18 2021, 02:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 05:33 AM |
