| RiqueMar |
Jul 18 2021, 04:25 PM
Enrique Allen Mar ![]() ![]() ![]() ![]() Group: Members Posts: 2,264 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California
Wrapping up a re-check of my rear-brakes, and I can’t seem to make either of these clips ‘fit’ on the suspension arms. Granted, my arms are reinforced, however I feel like I’m missing something. Hoping the world can help, as the search feature brings up photos that I can’t quite see. (IMG:style_emoticons/default/bye1.gif)
| SirAndy |
Jul 18 2021, 04:50 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,455 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
One more, from a 928, but the same parts:
(IMG:http://www.914world.com/bbs2/uploads_offsite/cimg3.ibsrv.net-179-1626648599.1.jpg) |
| RiqueMar |
Jul 18 2021, 06:34 PM
Thanks everyone! I think these might have been modified in the past, maybe when they were reinforced, because I can’t get the U-shaped clip inside, looks like I have to either cut them to make a bit shorter, or trim off the side.
| bdstone914 |
Jul 19 2021, 07:06 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,268 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Thanks everyone! I think these might have been modified in the past, maybe when they were reinforced, because I can’t get the U-shaped clip inside, looks like I have to either cut them to make a bit shorter, or trim off the side. @RiqueMar If you have a 70 as indicated in your avatar you would need the hat shaped clip. SirAndy is correct if you have a later car. The flex line needs to match the clip used. The early trailing arms have a rounds hole in the support bracket and the later cars have a round hole opening to a slot. It is taller. The late clip will not fit on an early car. Cant tell from your picture which you have. I think you picture late flex lines. Edit: I see you posted a pictures which show you have one early and one late arms. You need the hat shaped clip on the early and the U shape clip on the late and the correct matching lines. This clip needs to be rotated 90 degrees Attached image(s)
| RiqueMar |
Jul 19 2021, 06:05 PM
If you have a 70 as indicated in your avatar you would need the hat shaped clip. SirAndy is correct if you have a later car. The flex line needs to match the clip used. The early trailing arms have a rounds hole in the support bracket and the later cars have a round hole opening to a slot. It is taller. The late clip will not fit on an early car. Cant tell from your picture which you have. I think you picture late flex lines. Edit: I see you posted a pictures which show you have one early and one late arms. You need the hat shaped clip on the early and the U shape clip on the late and the correct matching lines. This clip needs to be rotated 90 degrees Hi @bdstone914 - Pretty sure my arms match, I think you're looking at another photo. I'm headed home now, and I'll try the hat-shaped clip, but this time on the bracket facing the 'front' side of the car. |
| bdstone914 |
Jul 19 2021, 06:31 PM
If you have a 70 as indicated in your avatar you would need the hat shaped clip. SirAndy is correct if you have a later car. The flex line needs to match the clip used. The early trailing arms have a rounds hole in the support bracket and the later cars have a round hole opening to a slot. It is taller. The late clip will not fit on an early car. Cant tell from your picture which you have. I think you picture late flex lines. Edit: I see you posted a pictures which show you have one early and one late arms. You need the hat shaped clip on the early and the U shape clip on the late and the correct matching lines. This clip needs to be rotated 90 degrees Hi @bdstone914 - Pretty sure my arms match, I think you're looking at another photo. I'm headed home now, and I'll try the hat-shaped clip, but this time on the bracket facing the 'front' side of the car. That should work if you have the correct flex lines. SirAndy posted very good pictures of the assemble order. |
RiqueMar Rear-Brakeline Brackets Jul 18 2021, 04:25 PM
Shivers The 'U' shaped one Jul 18 2021, 04:32 PM
SirAndy The flexible brake line goes through the hole in t... Jul 18 2021, 04:45 PM
SirAndy Maybe this shows it better. The top clip in the fr... Jul 18 2021, 04:47 PM
Thanks everyone! I think these might have bee... Jul 18 2021, 06:57 PM
RiqueMar @SirAndy - Looks like it’s the bracket itself, ... Jul 18 2021, 07:56 PM
Shivers
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jul 18 2021, 11:03 PM
Shivers Was the bracket cut off, then welded back on? I we... Jul 18 2021, 10:58 PM
fixer34 don't want to hijack this thread, but the ques... Jul 19 2021, 03:13 PM
SirAndy So will I need the 'C' clip also?
If this ... Jul 19 2021, 04:00 PM
bdstone914
don't want to hijack this thread, but the que... Jul 19 2021, 06:34 PM
Retroracer So reinforcing the rear arms can take a few forms ... Jul 19 2021, 07:18 PM
RiqueMar :D
Jul 20 2021, 09:06 AM
:D
:trophy: Jul 20 2021, 10:19 AM
RiqueMar
:D
:trophy:
Gracias to all, especially Señ... Jul 20 2021, 12:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th March 2026 - 01:02 AM |
