Any suggestions on how to fix my uneven headlights?, Left side goes all the way up but right side stops a bit short? |
Dominic |
Jul 25 2021, 03:19 PM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
My headlight motors appear to function normally, but the right one stops short of going to the full up position. I can manually turn the screw on the back to get them even, but it wont go full up on it's own. Any suggestions?
Thanks, Dominic |
ClayPerrine |
Jul 26 2021, 07:16 AM
Life's been good to me so far..... Group: Admin Posts: 15,520 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
My headlight motors appear to function normally, but the right one stops short of going to the full up position. I can manually turn the screw on the back to get them even, but it wont go full up on it's own. Any suggestions? Thanks, Dominic 1. Loosen the headlight stop screw so it won't contact the stop. 2. Turn the headlights on and remove the relay so they stay up. 3. Remove the arm from the motor and reposition it so the arm is at maximum extension. 4. Adjust the stop screw so it makes contact with the headlight stop. Clay |
Dominic |
Jul 26 2021, 07:14 PM
My headlight motors appear to function normally, but the right one stops short of going to the full up position. I can manually turn the screw on the back to get them even, but it wont go full up on it's own. Any suggestions? Thanks, Dominic 1. Loosen the headlight stop screw so it won't contact the stop. 2. Turn the headlights on and remove the relay so they stay up. 3. Remove the arm from the motor and reposition it so the arm is at maximum extension. 4. Adjust the stop screw so it makes contact with the headlight stop. Clay Thanks Clay, I will try that! |
Lo-Fi Version | Time is now: 9th June 2024 - 09:16 PM |
