worn hub washer |
worn hub washer |
JFG |
Aug 4 2021, 01:02 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
bdstone914 |
Aug 4 2021, 01:27 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Which side of the nut or bearing was contacting that surface?
What is under the washer ? Over tightening usually results in a burned up bearing. And what are gubbins ? |
JFG |
Aug 4 2021, 01:52 PM
Which side of the nut or bearing was contacting that surface? What is under the washer ? Over tightening usually results in a burned up bearing. And what are gubbins ? gubbins is generic for bits n bobs. the worn side was against the smaller outer bearing. There is no damage to the bearing or the housing. |
Lo-Fi Version | Time is now: 10th June 2024 - 08:17 AM |
