Need help with 1970 ignition switch removal without the key |
fiacra |
Aug 7 2021, 08:44 PM
Person.Woman.Man.Camera.TV Group: Members Posts: 339 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
Anybody know a way to get the ignition tumbler out on a 1970 if you don't have the key? This is a car I acquired that had been sitting for two decades and did not have keys. I've spent hours researching this, reading threads, reading MarkB's tech article, but still haven't figured out if there is a way to do this without a key. I did take the door lock in and had a key made, but it does not work on the ignition. I tried to see if I could get it out without releasing the steering wheel lock, but could not. I had a mobile locksmith come out and after a full hour, and using up three of my key blanks, he gave up and said he would send his "boss" out to do it. He never showed up... I've since called three more locksmiths and all of them have said they need to do more research and then call me back. I did get back in touch with them and one said he doesn't think he can do it, and the other two still want more time to research. I'm at the point where I think I have to drill it out, but wanted to ask the collective if anybody has any further thoughts on this. I know these tumblers are hard to find...but I also saw a reputable member selling several NOS tumblers with VW part number 17319-05442135 that they said would work for a 1970 914. That's a tumbler for a 1968-70 Beetle, and while NOS parts are not easily available, those are easily available aftermarket. https://www2.cip1.com/ProductDetails.asp?Pr...113%2D905%2D853
Still, I don't want to drill it out unless I can confirm this would work... Any advice would be appreciated. Thanks! |
markb |
Aug 8 2021, 12:49 AM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
This is a shot in the dark, but does the door key also work in the other locks on the car? If it doesn't work in the glovebox lock, take the glovebox lock to the locksmith and have a key made for it. You might luck out, if the ignition switch is the original.
fiacra |
Aug 8 2021, 09:14 AM
This is a shot in the dark, but does the door key also work in the other locks on the car? If it doesn't work in the glovebox lock, take the glovebox lock to the locksmith and have a key made for it. You might luck out, if the ignition switch is the original. That's one of those thoughts that is so sensible it is actually brilliant! No way to know if the ignition has been replaced, but the door key does not work on the glovebox lock so I'm going to pull it, take it in and see if the key will then fit the ignition. I'll let you know. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:35 PM |
