Moving battery to rear trunk - good spot? |
Tdskip |
Aug 9 2021, 10:29 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Hi folks, hope everybody had a good weekend. This car is going to have a 2.4 L carbureted/6 engine hurt but at some point in the future will need the hell hole tidied up. I just need to get the engine in and the car running so well I understand I’m creating more work for myself at some point in the future it’s time to get this thing moving under its own power.
Given that I am thinking about relocating the battery to the position as shown. I am imagining a plastic battery tray that simply bolted to the floor would be fine, but wanted to get some thoughts prior to diving in.. Thanks! (Sharp eyed people who have had their morning coffee will probably spot that there’s a 3.2 L in there, different plans for that motor) |
GregAmy |
Aug 9 2021, 10:49 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I installed a lightweight AGM battery immediately above the starter (to shorten the positive cable length to the starter) and the ground cable to the standard ground point above the transaxle tail. The cables go through holes in the floor, protected by grommets.
Since the battery is an AGM, I mounted it on its side so the terminals go straight down. The terminals are protected from contact of junk in the trunk by rubber covers. https://braillebattery.com/collections/lightweight-agm https://braillebattery.com/collections/mounts |
Lo-Fi Version | Time is now: 1st June 2024 - 02:22 AM |
