I’ve made a (not super bad) rusty mistake |
Shackleford |
Aug 9 2021, 05:16 PM
Newbie Group: Members Posts: 35 Joined: 9-August 21 From: Ca Member No.: 25,788 Region Association: None |
Hello!
I’m new here been lurking for like a year. Finally got a 914. Thought I did it somewhat right. But the car has hell hole rust. Long story short a, fresh battery tray had been screwed in and hell hole issue was not visible in any of the pics even the ones from under battery tray because some putty or something had been kinda smooshed over it and it was very dirty..anyway I’m dumb I had a local friend of a friend look at car and take pics of usual areas but I missed it and so did he. Owner also totally lied about stuff but that’s a different story. Anyway, car is sadly mine now and I am wondering if it’s ok to drive it like this for a while? I treated rust with Krud Kutter rust remover and I’m gonna primer it to stop more rust in the VISIBLE areas. I’m gonna see about getting it fixed but can I drive it for the summer you think? Then get it fixed when it starts raining? The hole on the left closest to the engine is what I discovered. The holes on the bottom and right (exterior side) are what I made with a screwdriver and wire wheel. Those did not exist until I started poking at it. Most of the metal seems pretty solid except those spots at the bottom. Thanks! |
Shackleford |
Aug 9 2021, 06:16 PM
Wow.
Thanks for the fast responses! It runs and drives great. I had the brakes gone through and it got a little tune up and valve adjustment when it arrived. Original fuel injection. 1.7. Seems nice and peppy. It sometimes grumbles about starting when it’s hot after a long-ish drive but give it a little gas and it starts. The underneath is super dirty. I’m getting it dry ice blasted soon. I’m also gonna remove the rocker panels and check that area soon. Thanks! Here are some more pics of the underside. |
Lo-Fi Version | Time is now: 8th June 2024 - 01:00 AM |
