> What HP level requires transmission upgrades?, I have 200 HP to the wheels, what do I need?
FourBlades
post Aug 6 2021, 09:42 AM
From Wreck to Rockin
I realize it is probably torque that kills a transmission, but I don't know the torque output of my engine.
I am building a 901 transmission for my IMSA 914 and wonder what upgrades it will need. I have some possible upgrades I could do now.
First, I have a set of 930 stub axles, CVs and the corresponding sway-away axles for a 914. They are stronger and the CVs are available for $80 from pelican. Downside is I have to destroy the existing rear bearings in my axles to use them, which were rebuilt by PMB.
If I have 200 HP to the wheels are the 930 CVs a necessary or worthwhile upgrade?
Second, should I upgrade to the billet intermediate plate at this HP level?
If I do, will I have to reset the pinion depth? That is something I can't do myself and would need to find a shop here in Florida that can do it. I know this is overkill for a typical 914, but with 12 inch rear tires and a 2.5L six, is this when the upgrade is worth while?
I am not adverse to starting with the 914 axles and upgrading down the road. Pulling the engine and transmission is not that time consuming. I would hate to break the smaller axles or CVs the first time at the track though.
I have a stock gearset and know there are probably better gear choices for Sebring, Daytona, etc. No idea where to start with those.
I will be running a transmission cooler to start and may move to gear set spray bar over time. I have read that the mesh point of the gears is where to aim the cool oil sprays, not sure this is correct.
I appreciate any advice people have.
John
FourBlades
post Aug 6 2021, 05:48 PM
Thanks Steve, this is really a big help!
I have not picked a wheel and tire combination yet, so I will hold off on picking new gears. I imagine some of these gear sets are rare and expensive.
John
wndsrfr
post Aug 9 2021, 08:55 PM
I'm at 215rwhp and run about 10 events per year on the 901's. Yes, driver error adds to transmission becoming a "consumable" like tires. I'm using two trannys now, one is AFMSX for short tracks like Roebling and Summit Point and the other is AFNSZA for VIR, Daytona, Sebring, Watkins Glen. I'm on 24 inch diameter rear tires. There's a really neat worksheet here:
http://www.914world.com/specs/regearing_901.php
--it's an excel spreadsheet that you can experiment with to choose tire diameter & gearing.
I pull the magnetic drain plug after each event & usually find a halo of "hair". ON occasion there will be a chip or sliver from driver clumsiness. I've found that one box or the other needs medical attention maybe once a year. In my opinion, get two trans's--keep one stock gearing and set the other with AFNS for 1-4th and find a ZA for 5th or just use a flipped N for 5th as a Z to start with. As you gain experience you'll likely try different combo's.
Not a "real" expert but I think if you replace intermediate plate then you'll need to set R/P depth again...
FourBlades   What HP level requires transmission upgrades?   Aug 6 2021, 09:42 AM
mepstein   I would ask Glenn/GMS for suggestions   Aug 6 2021, 10:01 AM
slivel   My Experiences: I ran a 914 transmission in a dedi...   Aug 6 2021, 12:03 PM
brant   A 914 race builder out here…. Recommends 205hp a...   Aug 6 2021, 01:04 PM
Justinp71   Some good advice in here. Seems like you would be ...   Aug 6 2021, 02:29 PM
slivel   For gear ratio selection, You want to be at redlin...   Aug 6 2021, 02:49 PM
FourBlades   Thanks for the great replies everyone! Seems ...   Aug 6 2021, 04:13 PM
Charles Freeborn   Thanks for the great replies everyone! Seems...   Oct 13 2022, 02:37 AM
slivel   I think that I used -8 lines on my car. Regarding...   Aug 6 2021, 04:54 PM
FourBlades   Thanks Steve, this is really a big help! I ha...   Aug 6 2021, 05:48 PM
wndsrfr   I'm at 215rwhp and run about 10 events per yea...   Aug 9 2021, 08:55 PM
stownsen914   My racecar has ~260 hp and has run a 901 for years...   Aug 10 2021, 04:42 PM
Justinp71   My racecar has ~260 hp and has run a 901 for year...   Aug 12 2021, 09:56 AM
stownsen914   Stock 914 cvs and axles are holding up well on th...   Aug 13 2022, 03:47 PM
mb911   My racecar has ~260 hp and has run a 901 for yea...   Oct 8 2022, 09:12 AM
slivel   In my experience, the stock CV's will survive ...   Aug 13 2021, 09:48 AM
BlueRidge914   Since keeping a 901 in one piece is an old and ong...   Aug 12 2022, 08:37 AM
BlueRidge914   ... oops let's try for a more useful pic size...   Aug 12 2022, 12:17 PM
brant   I think that high rpm also has an impact on transm...   Aug 13 2022, 05:26 PM
stownsen914   Horsepower can be managed with cooling. Torque can...   Aug 14 2022, 09:17 AM
Brett W   If you need to build a new race gear box, I would ...   Sep 24 2022, 08:29 AM
campbellcj   My experience has been similar to above. My box ha...   Oct 18 2022, 05:57 PM
Charles Freeborn   My experience has been similar to above. My box h...   Oct 19 2022, 08:13 PM
campbellcj   I have it on rather good authority that the Int...   Oct 20 2022, 06:48 PM
campbellcj   http://www.914world.com/bbs2/uploads_offsite/live....   Oct 24 2022, 11:09 AM
- Lo-Fi Version Time is now: 26th September 2025 - 07:22 AM
