> I need help with rear trunk torsion bar, How do I get the bar behind the roller?
Doug Leggins
post Oct 4 2005, 08:55 PM
The teener kicked my ass tonight! I simply wore myself out trying to get the rear trunk torsion bar behind the trunk roller.
I searched for as much info as I cold find before beginning this task. I modified my 12" adjustable wrench as mentioned on other threads on this topic. This tool proved to be a very good lever for pushing the torsion bar back. I could get the torsion bar pushed/twisted back well enough but I could not get it around the hinge roller/pin. I tried several times but could not find a way to get the roller behind the pin on the hinge.
I tried to remove the hinge then hold the torsion bar back as far as I could and then reinstall the hinge -This is the task the wore me out! No matter how or what I tried I could not find a way to get the bar behind the roller.
Anyone know the secret/technique to get the torsion bar in place?
Here is a pic of the wrench with a notch cut out on the end.
jrmdir
post Aug 10 2021, 11:19 AM
[/quote]
How did you determine the location of the JWest brackets? I have them and the tool to do this job. Was the engine installed when you did it?
[/quote]
Yes the engine is in and I removed the trunk lid. The kit is great but the instructions about locating the right spot for the holes didn't sound easy to me: Put the lid back on and do the trial and error thing!
So I figured the best thing would be to try to make sure the center of the new bolt lined up with where the prior center of the welded bracket had been. So before I ground off the spot welds, I spent some time re-forming the broken off bracket until it fit back where it was - with the broken edges lined up with the metal still on the car. Then I screwed the old mounting bolt most of the way through (see photo) put a dab of white grease on the end and set it back in place so the grease transferred to the body. Probably overkill bc there was a definite dimple stamped into the body right were the grease ended up. Not sure if this was a a factory guide point but it seemed so. I only had to to one side so I don't know if they're all like that.
Next I drilled a 5/16 hole at that center point. (start with a 1/8" drill and work up because there is a 2nd layer of metal partially behind that will cause a larger drill to walk off center. AMHIK!) Finally, I found a suitable bushing to allow me to put a longer 5/16 bolt through the large rod end hole, added a thin washer and stuck it through the new hole in the body with a nut and washer on the wheel well side.
So, with the pivot point theoretically right where it used to be, I was able to rotate the new bracket around to find the best clearance for the four bolts and scribe for the bolt holes.
So after all this verbiage, the big disclaimer is that I've yet to reinstall the lid - but will do that today. However since I drilled larger mounting holes as suggested - for adjustment - I'm pretty confident it will work out just fine.
Ron
Doug Leggins   I need help with rear trunk torsion bar   Oct 4 2005, 08:55 PM
Doug Leggins   Trying to bet the black torsion bar behind the bra...   Oct 4 2005, 09:03 PM
Rand   Taking mine OUT was a careful process... putting o...   Oct 4 2005, 09:07 PM
Joe Sharp   Doug: I take my 1/4 screw driver extention and a d...   Oct 4 2005, 10:06 PM
Air_Cooled_Nut   Though I can't help, this topic is perfect bec...   Oct 4 2005, 10:19 PM
olav   To get that puppy on you need to: Preload torsion...   Oct 4 2005, 10:51 PM
Doug Leggins   I thought about the shock kits, even had it on the...   Oct 4 2005, 10:53 PM
olav   There's a "special" tool to do this with and t...   Oct 4 2005, 10:59 PM
Doug Leggins     Oct 4 2005, 11:08 PM
hmeeder   I used this method once upon a time when my hinge ...   Oct 4 2005, 11:14 PM
plas76targa   Doug, To replace a broken plastic roller with an ...   Oct 5 2005, 06:00 AM
ClayPerrine   As was said previously, use a box end wrench to mo...   Oct 5 2005, 08:50 AM
aircooledboy   I have had to do this 3 times to repair my pivot h...   Oct 5 2005, 10:58 AM
flesburg   Guys !!!!!!!!...   Oct 5 2005, 02:52 PM
ClayPerrine   Dale, The cresent wrench modification mentioned ...   Oct 5 2005, 03:46 PM
Joe Sharp   Doug: I takt the 5/16th deep well and slip it on a...   Oct 5 2005, 04:20 PM
Headrage   Excellent solution Joe.   Oct 5 2005, 05:10 PM
Joe Sharp   Thanks Allan. But its not mine, I read it on the b...   Oct 5 2005, 06:19 PM
jsteele22   Car looks sweet, BTW (I'm thinking of convert...   Oct 5 2005, 06:42 PM
Doug Leggins   SUCCESS!!!! http:/...   Oct 5 2005, 08:30 PM
Doug Leggins   transitioning from the 1/4" extension to the notch...   Oct 5 2005, 08:32 PM
Doug Leggins   Using the notched wrench to push the torsion bar f...   Oct 5 2005, 08:36 PM
Doug Leggins   Reaching in from the engine bay with a large screw...   Oct 5 2005, 08:37 PM
Doug Leggins   Screwdriver used to pry the bar around the end of ...   Oct 5 2005, 08:40 PM
Doug Leggins   Torsion bar on the back side of the roller pin...   Oct 5 2005, 08:41 PM
Doug Leggins   Slipped the roller on the pin, cautiously eased up...   Oct 5 2005, 08:45 PM
Lou W   This belongs in the Classic Thread Section. http://www.914world.com/b...   Oct 5 2005, 09:01 PM
jsteele22   Wow, is there anything in your car that isn't ...   Oct 5 2005, 09:20 PM
seanery   ...   Oct 6 2005, 12:07 AM
ClayPerrine   This is a nice picture representation of the proce...   Oct 6 2005, 10:10 AM
Mikey914   No need to make the tool, this looks like the tech...   Nov 28 2017, 12:05 PM
JOEPROPER   :bump: Just bumping this thread because it's r...   Apr 14 2020, 07:46 AM
JOEPROPER   This helped. ALOT. 5 minutes or less with no hel...   Apr 14 2020, 08:05 AM
AZBanks   Great thread. I am going to need it because I have...   Apr 14 2020, 09:10 AM
JOEPROPER   Great thread. I am going to need it because I hav...   Apr 14 2020, 10:16 AM
Jakester1   DOUG, thank you for the great pic's of install...   May 5 2020, 09:44 AM
dt4   tomorrows job is it done with the trunk lid on the...   May 31 2020, 01:51 PM
IronHillRestorations   tomorrows job is it done with the trunk lid on th...   May 31 2020, 04:20 PM
BeatNavy   It can be done with trunk on the hinges. Be caref...   May 31 2020, 06:05 PM
rhodyguy   Prop the trunk fully, FULLY, open for a lid on rol...   Jun 1 2020, 09:17 AM
dt4   defeated me today, it took plenty of effort just t...   Jun 1 2020, 11:27 AM
Mikey914   We just brought on McMark's tool for doing the...   Jun 1 2020, 11:55 AM
Arno914   Place some thick cushioning on the area where the ...   Aug 27 2020, 06:25 AM
Garland   Great tool, glad these are still available, got mi...   Sep 13 2020, 02:33 PM
Mikey914   Link https://914rubber.com/rear-trunk-spring-pre....   Sep 13 2020, 06:02 PM
jrmdir   Older thread but Doug still deserves kudos for the...   Aug 10 2021, 08:57 AM
NARP74   Older thread but Doug still deserves kudos for th...   Aug 10 2021, 09:58 AM
ClayPerrine   How did you determine the location of the JWest b...   Aug 10 2021, 01:21 PM
tomh   I notched an old flat crow bar It worked great.   Aug 10 2021, 09:43 AM
jrmdir   Success! I've owned this car for over 2 m...   Aug 10 2021, 02:32 PM
- Lo-Fi Version Time is now: 25th November 2026 - 05:21 PM
