Front trunk handle removal |
RiqueMar |
Aug 9 2021, 05:53 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Hi all, I’m sure it’s been a topic before, but I can’t seem to find any resource in extracting the lock / handle from the front-trunk. Can anyone point me in the right direction for a thread or provide some help?
Thank! (IMG:style_emoticons/default/bye1.gif) |
PCH |
Aug 10 2021, 01:42 PM
Member Group: Members Posts: 143 Joined: 3-January 19 From: Santa Barbara Member No.: 22,772 Region Association: Southern California |
On a similar vein, is it possible to remove the tumbler from the latch handle with out removing the cable? It's the last lock on my car that I have to rekey.
bbrock |
Aug 10 2021, 05:00 PM
On a similar vein, is it possible to remove the tumbler from the latch handle with out removing the cable? It's the last lock on my car that I have to rekey. Sort of. There is a small set screw on the T-handle housing that holds the tumbler in the housing. You have to pull the handle far enough out of the bracket tube to access that handle. My bet is it will require unhooking the cable at the latch as @bkrantz described. At that point, you might as well just unscrew the cable from the handle and take the handle to the bench for re-keying. One addition to Bob's handle removal instructions. There is (or should be) a small screw on the bottom that goes through a slot in the bracket and into the handle to act as a stop to limit how far out you can pull the handle. That needs to be removed to pull the handle out of the bracket too. |
RiqueMar |
Aug 10 2021, 05:04 PM
On a similar vein, is it possible to remove the tumbler from the latch handle with out removing the cable? It's the last lock on my car that I have to rekey. Sort of. There is a small set screw on the T-handle housing that holds the tumbler in the housing. You have to pull the handle far enough out of the bracket tube to access that handle. My bet is it will require unhooking the cable at the latch as @bkrantz described. At that point, you might as well just unscrew the cable from the handle and take the handle to the bench for re-keying. One addition to Bob's handle removal instructions. There is (or should be) a small screw on the bottom that goes through a slot in the bracket and into the handle to act as a stop to limit how far out you can pull the handle. That needs to be removed to pull the handle out of the bracket too. I was able to do this last night and snapped a few photos as well, step-by-step coming shortly (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 11:28 AM |
