Power Bleeder - Looking for recommendations |
RiqueMar |
Aug 16 2021, 12:12 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Hi Everyone
Looking for recommendations on brake bleeders / power bleeders. What have you got, where did you get it, and do you like it? (IMG:style_emoticons/default/bye1.gif) |
branston |
Aug 17 2021, 06:57 AM
Member Group: Members Posts: 89 Joined: 17-October 12 From: Michigan Member No.: 15,053 Region Association: Upper MidWest |
I just received my motive, $58 shipped, bought directly from Motive. Be sure to buy the European version, SKU is MP-0100. I can confirm the enclosed cap fits my Porsche fluid reservoir.
I'll be using it this week and will report back on its functionality! |
branston |
Aug 18 2021, 08:24 PM
I just received my motive, $58 shipped, bought directly from Motive. Be sure to buy the European version, SKU is MP-0100. I can confirm the enclosed cap fits my Porsche fluid reservoir. I'll be using it this week and will report back on its functionality! I got to bleed the brakes today using the Motive Power bleeder, Frankly, I'm impressed!. I used it on my 912E as I'd replaced the master cylinder, the 914 has a similar. However, I didn't use it per the instructions, using it dry. i topped up the reservoir with fresh DOT3, pressurized the bleeder with the intention only to push out the old fluid. It worked so well, I just topped up the reservoir before bleeding each corner, I pumped the empty power bleeder like crazy to get 5-10psi and opened each bleeder in turn, topping up the reservoir between corners. The result, a good hard pedal with no pumping, completed alone! I'm sold on this thing. Just a word of warning. my 912E has a reservoir overflow, piped to under the front bumper, I couldn't figure out why brake fluid was dripping under the front apron until I realized I needed to clamp the 6mm flex line. Duh. My 914's brake fluid reservoir doesn't have this overflow connection. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:24 PM |
