| bbrock |
Mar 20 2019, 08:55 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
I didn't want to hijack the other thread but have a question about my own Webers. They are Italian 40IDFs I bought in the late 80s or early 90s. Other than finger tight bolting them on to my engine to see how cool they looked, they have never been used. No fuel has touched them. I don't remember if I even opened them to set the float levels. BUT... they were stored in a humid basement for several years before I moved to a civilized climate. So, the magnesium housing is tarnished on the outside and the plating has deteriorated on a few of the levers and such. Pretty minor stuff from what I can see.
My question: is there is anything special I should do or check other than inspecting for corroded parts and normal setup as I prep these for service? |
| bbrock |
Aug 21 2021, 12:05 PM
At one point I had plans to add a 914-6 throttle lever in front of the shifter and run bicycle cables back to the cold start valves to operate them like the heater valves. That was before learning those valves are prone to stick open and cause the carbs to run dangerously rich.
bbrock Reviving NOS Webers Mar 20 2019, 08:55 PM
914_7T3 Are you really going to go through with it? After... Mar 20 2019, 09:47 PM
bbrock
Are you really going to go through with it? Afte... Mar 21 2019, 08:13 AM
MarkV If nothing else I would take them apart and do a t... Mar 20 2019, 10:07 PM
Mark Henry :agree: take them apart, clean, blow out*, etc.
C... Mar 21 2019, 05:57 AM
rgalla9146
... Mar 21 2019, 06:04 AM
Superhawk996 Be brave. Put on and see what they do.
If store... Mar 21 2019, 07:45 AM
tmessenger The float needle tip can harden with age so I repl... Mar 21 2019, 07:53 AM
Superhawk996 Just to add a little more context.
My car had b... Mar 21 2019, 07:56 AM
Superhawk996 Not trying to start a :stromberg: storm but I do... Mar 21 2019, 08:04 AM
tmessenger Here's a photo of the needle that came out of ... Mar 21 2019, 09:15 AM
dr914@autoatlanta.com Richard at PMO is a great sounding board for any w... Mar 21 2019, 09:28 AM
bbrock
The float needle tip can harden with age so I rep... Mar 21 2019, 08:21 AM
Superhawk996 :worship:
I learned something. Thank you.
My... Mar 21 2019, 09:37 AM
Chi-town You'll want to replace all the original rubber... Mar 21 2019, 09:55 AM
MarkV If you are putting them on a fresh engine with fre... Mar 21 2019, 08:13 PM
Superhawk996
If you are putting them on a fresh engine with fr... Mar 22 2019, 10:13 AM
bbrock
Bottom line: Brent is fastidious and his attenti... Mar 22 2019, 11:46 AM
Superhawk996 :unsure:
Wow. I'm looking for the eating c... Mar 22 2019, 12:34 PM
bbrock
:unsure:
Wow. I'm looking for the eating ... Mar 22 2019, 12:42 PM
timothy_nd28
:unsure:
Wow. I'm looking for the eating... Mar 22 2019, 02:33 PM
bbrock
Basement walls sweating is not a good thing at al... Mar 22 2019, 03:00 PM
porschetub
:unsure:
Wow. I'm looking for the eating ... Sep 6 2020, 02:17 AM
Superhawk996 How about this one
I got :owned: Mar 22 2019, 12:37 PM
Tdskip
How about this one
I got :owned:
Nah - your as... Jun 20 2019, 07:18 AM
How about this one
I got :owned:
Nah - your a... Jun 20 2019, 07:35 AM
johnhora Brent,
Those are in good shape for the age and am... Mar 22 2019, 12:40 PM
bbrock
Brent,
Those are in good shape for the age and a... Mar 22 2019, 12:50 PM
Superhawk996 I'm in Detroit and we get lots of humidity but... Mar 22 2019, 12:50 PM
johnhora Pierce Manifold is very good as are others..
https... Mar 22 2019, 01:08 PM
MarkV My DRLA 40's have some of that white staining ... Mar 22 2019, 02:07 PM
bbrock
Not sure why they came with 28's.... they mig... Mar 22 2019, 02:23 PM
MarkV
Not sure why they came with 28's.... they mi... Mar 22 2019, 02:44 PM
rhodyguy As noted, the 40s would have come with 28mm Ventur... Mar 23 2019, 08:15 AM
bbrock More good info guys. I appreciate it. This is ma... Mar 23 2019, 08:36 AM
Superhawk996 Back in the day (meaning when I was younger and le... Mar 23 2019, 09:30 AM
porschetub 28mm vents will work fine,they will offer a great ... Mar 23 2019, 02:59 PM
bbrock I finally got around to this project. I have the ... May 21 2019, 08:22 PM
mepstein If you send them to me, I'll vapor blast them ... May 21 2019, 09:08 PM
bbrock
If you send them to me, I'll vapor blast them... May 22 2019, 07:26 AM
72hardtop At your altitude stay with the 28mm vent size comb... May 30 2019, 02:42 PM
bbrock
At your altitude stay with the 28mm vent size com... May 31 2019, 09:13 AM
porschetub
At your altitude stay with the 28mm vent size com... Jun 1 2019, 12:24 AM
bbrock Carbs are finally cleaned up and back together. T... Jun 19 2019, 10:18 AM
rhodyguy Get the CB Weber manual. 2056? Refresh my memory. ... Jun 19 2019, 10:55 AM
bbrock
Get the CB Weber manual. 2056? Refresh my memory.... Jun 19 2019, 11:11 AM
rhodyguy OK, the 28s should be fine. A little short on the ... Jun 19 2019, 11:19 AM
IronHillRestorations Here's my carb tuning procedure from a March 0... Jun 20 2019, 06:53 AM
ThePaintedMan Nice job. :headbanger: Highly recommend you spra... Jun 20 2019, 02:23 PM
bbrock
Nice job. :headbanger: Highly recommend you spr... Jun 20 2019, 02:34 PM
72hardtop What elevation you at? (My jetting is a few hundre... Sep 6 2020, 01:26 AM
IronHillRestorations I went back and re-read some of this thread. I... Sep 6 2020, 11:50 AM
bbrock
I went back and re-read some of this thread. I... Nov 22 2020, 07:13 PM
bbrock I was surprised to see this old thread pop up agai... Sep 6 2020, 12:17 PM
72hardtop My procedure....
Start and warm up the engine.
Ma... Nov 2 2020, 06:19 AM
Gint I've had this thread open in a browser tab on ... Nov 21 2020, 09:09 AM
nditiz1 I haven't ever converted them to disabled as t... Nov 22 2020, 08:10 PM
bbrock
I haven't ever converted them to disabled as ... Nov 22 2020, 08:26 PM
914werke Interesting, I happen to be working on a customers... Aug 19 2021, 02:23 PM
Interesting, I happen to be working on a customer... Aug 20 2021, 04:47 AM
914werke If they were mine I might take this approach, but ... Aug 20 2021, 07:52 AM
IronHillRestorations I've never seen the cold start enrichment used... Aug 20 2021, 12:18 PM
914werke I've never seen the cold start enrichment use... Aug 21 2021, 11:58 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th November 2026 - 12:16 AM |
