Fan Belt Help |
Fan Belt Help |
Ken Mikos |
Aug 22 2021, 07:31 PM
Newbie Group: Members Posts: 28 Joined: 20-February 14 From: Pgh Member No.: 17,024 Region Association: None |
Just put a new fan belt on, it jumped off the pulleys twice as I was driving after about 10 miles.
The old belt had inner cogs and the new belt has outer cogs. Will that make a difference? I made sure the belt was tight the first time and probably over tightened it the second time as I had only about a 1/4” of flex. Any suggestions would be appreciated. Thanks |
Ken Mikos |
Aug 23 2021, 02:10 PM
Thanks for all the constructive comments.
Checked the Alt Pully, no play or bends and the Alt Bracket is fine. The newer belt that spun off has the same ID #15380 but is slightly different than the old belt as described earlier. To remedy the issue I temporally installed the old belt and placed an order for a Conti 10X965 which has the cogs on the inside. Will keep you all updated on this bizarre issue. Ken |
Lo-Fi Version | Time is now: 9th June 2024 - 02:51 PM |
