Tires needed, what are biggest tires to fit unmodified front fenders. |
Movin6 |
Aug 18 2021, 03:21 PM
Member Group: Members Posts: 76 Joined: 27-July 09 From: New England Member No.: 10,615 Region Association: North East States |
Failed my state inspection for front tires... (How I never looked at the front tires while I had it on the lift for a week doing valve adjust, I'll never know...)
I have 225 50 R15 on rear, (Rears are slightly flaired, Front fenders appear stock.) 195 50 R15 on front with 6 1/5 15" rims all around. (Same sizes as it came from PO, with Yokohama A008 which I also had a set of.) I have relatively new rears, was thinking of going with the same 195 50 15 for front replacement, but when I called Tire Rack they suggested those were small tires... (LOL load rating is 1,047 lbs per tire...) But it raises the question - Should I consider a larger front tire? I'm guessing the 225 50 15 rears won't fit (I plan to jack it up and swap a rear to the front to confirm.) Thoughts? What are others doing, and should I change? (Have Kuhmo ECSTA AST on rear - A "High Performance All Season', so can match with a similar 195 50 15, I no longer track the car as when I ran the Yoko A008s...) |
SKL1 |
Aug 23 2021, 09:26 PM
Senior Member Group: Members Posts: 1,605 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
205's all the way around work great and are plenty of tire for that car. Just don't try and use Riviera wheels as the offset is wrong and you're lucky to get 165 or 185's to fit.
Lo-Fi Version | Time is now: 9th June 2024 - 06:20 AM |
