Changing Alternator Belt |
kbrunk1 |
Sep 26 2012, 07:53 PM
Brunk Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
balljoint |
Sep 27 2012, 04:16 AM
914 Wizard Group: Members Posts: 10,000 Joined: 6-April 04 Member No.: 1,897 Region Association: None |
I find it easier to pull on the alternator from the passenger side of the engine bay once you have the adjustment nut loose. The pivot bolt on the bottom is a pain to get to so if you can avoid loosening it... (IMG:style_emoticons/default/unsure.gif)
Jamie |
Aug 28 2021, 06:08 PM
Senior Member Group: Members Posts: 1,035 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
I find it easier to pull on the alternator from the passenger side of the engine bay once you have the adjustment nut loose. The pivot bolt on the bottom is a pain to get to so if you can avoid loosening it... (IMG:style_emoticons/default/unsure.gif) Can you guys supply a fan belt part number, I want to buy a spare to carry while traveling. Dad left 2 different length belts in the car long ago and they are quite stiff by now and not to be trusted. (IMG:style_emoticons/default/confused24.gif) |
930cabman |
Aug 28 2021, 10:17 PM
Advanced Member Group: Members Posts: 3,144 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I find it easier to pull on the alternator from the passenger side of the engine bay once you have the adjustment nut loose. The pivot bolt on the bottom is a pain to get to so if you can avoid loosening it... (IMG:style_emoticons/default/unsure.gif) Can you guys supply a fan belt part number, I want to buy a spare to carry while traveling. Dad left 2 different length belts in the car long ago and they are quite stiff by now and not to be trusted. (IMG:style_emoticons/default/confused24.gif) I got one at NAPA, local store had it on the shelf |
Jamie |
Aug 29 2021, 10:56 AM
I find it easier to pull on the alternator from the passenger side of the engine bay once you have the adjustment nut loose. The pivot bolt on the bottom is a pain to get to so if you can avoid loosening it... (IMG:style_emoticons/default/unsure.gif) Can you guys supply a fan belt part number, I want to buy a spare to carry while traveling. Dad left 2 different length belts in the car long ago and they are quite stiff by now and not to be trusted. (IMG:style_emoticons/default/confused24.gif) I got one at NAPA, local store had it on the shelf Did the NAPA belt have a part number, or did they have a cross reference that was correct? (IMG:style_emoticons/default/confused24.gif) |
930cabman |
Aug 29 2021, 01:00 PM
I find it easier to pull on the alternator from the passenger side of the engine bay once you have the adjustment nut loose. The pivot bolt on the bottom is a pain to get to so if you can avoid loosening it... (IMG:style_emoticons/default/unsure.gif) Can you guys supply a fan belt part number, I want to buy a spare to carry while traveling. Dad left 2 different length belts in the car long ago and they are quite stiff by now and not to be trusted. (IMG:style_emoticons/default/confused24.gif) I got one at NAPA, local store had it on the shelf Did the NAPA belt have a part number, or did they have a cross reference that was correct? (IMG:style_emoticons/default/confused24.gif) The NAPA P/N is NBH 25-7380. I would bet all our Type 4 (914/4 cyl) engines take the same belt. |
Lo-Fi Version | Time is now: 8th June 2024 - 10:06 AM |
