Replacing steering column wiper switch, should the brass tab be grounding to the steering column? |
seanpaulmc |
Dec 19 2016, 07:52 PM
Member Group: Members Posts: 304 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
The arm for the wiper switch coming out of the steering column in my '73 has been cut away. You can see that in the photos. Will this be hard to fix? Where can I source one?
Thank you! |
seanpaulmc |
Aug 31 2021, 11:03 AM
Well after a considerable amount of work to fit this aftermarket wiper switch to the OEM turn signal switch I may almost have it. Before fitting it to the car I have a clarification question for the team about this brass tab.
Is this brass tab supposed to ground to the steering column itself? I assume it should and I want to avoid taping over it completely when installing so that it will ground. Hope this works. Thanks, |
Lo-Fi Version | Time is now: 7th June 2024 - 09:15 PM |
