| Jetsetsurfshop |
Sep 1 2021, 07:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 815 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
I thought I'd share these pics. I never believed that a sway-bar would break. Anyone else seen this before?
Attached thumbnail(s) |
| Jetsetsurfshop |
Sep 2 2021, 07:29 AM
More pics. (IMG:style_emoticons/default/biggrin.gif)
| stownsen914 |
Sep 2 2021, 09:53 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 996 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
That's impressive.
Sometimes it's hard to tell after the fact, but is there any obvious sign of damage that might have led to the fracture. Sometimes if you clean it up well and look closely at the failed part, you can tell where the crack started and look for a stress riser like scoring on the surface or some other damage. Another thing I've noticed - I've set up a 911 and 914 with the through body front swaybar, and both of them had significant binding at triangular bushing mounts. Basically the vertical surfaces that the mount bolt to weren't parallel, so when mounted the bar really bound up to the point that I couldn't move it by hand at all. I had to put washers under two of the three triangular bushing mounts, on both sides of the car, to get them parallel. |
| Jetsetsurfshop |
Sep 2 2021, 10:59 AM
That's impressive. Sometimes it's hard to tell after the fact, but is there any obvious sign of damage that might have led to the fracture. Sometimes if you clean it up well and look closely at the failed part, you can tell where the crack started and look for a stress riser like scoring on the surface or some other damage. Another thing I've noticed - I've set up a 911 and 914 with the through body front swaybar, and both of them had significant binding at triangular bushing mounts. Basically the vertical surfaces that the mount bolt to weren't parallel, so when mounted the bar really bound up to the point that I couldn't move it by hand at all. I had to put washers under two of the three triangular bushing mounts, on both sides of the car, to get them parallel. We had to washer up mine to get it to move smoothly. When I removed what was left of the bar it moved great. No binding what so ever. I did find a video from a recent event where a dropped the passenger front wheel in turn one at Sebring. It was a pretty hard thud. Maybe I cracked it then?? The funny part if that I had a spin the next lap. I remember thinking that I wasn't really offline and the spin shouldn't have happened. I'll work on the video tonight. Maybe we have a smoking gun. |
| stownsen914 |
Sep 2 2021, 11:50 AM
Jetsetsurfshop I killed a sway-bar Sep 1 2021, 07:22 PM
infraredcalvin Wow, a tarrett as well!
Sent it to them see w... Sep 1 2021, 11:34 PM
Jetsetsurfshop
Sent it to them see ... Sep 2 2021, 07:23 AM
Shivers Wow, that is some hard charging Sep 2 2021, 05:22 AM
Jetsetsurfshop
I think the fou... Sep 2 2021, 07:24 AM
jd74914 Curious what the bar ends that are in the arm look... Sep 2 2021, 09:50 AM
914werke Is it a hollow bar ? Sep 2 2021, 12:19 PM
Jetsetsurfshop
It is a hollow bar. Sep 2 2021, 02:38 PM
sixnotfour hollow hybred..or lessbred..True hollows are thro... Sep 2 2021, 08:10 PM
stownsen914
True hollows are through hollow
Hadn't not... Sep 4 2021, 06:10 AM
Jetsetsurfshop Is the square end welded to the hollow bar?
[/quot... Sep 4 2021, 03:59 PM
stownsen914 I'd guess it failed at the weld (or right next... Sep 5 2021, 06:08 AM
Jetsetsurfshop a9Meh2OBiBY
You can see the wheel drop out of tur... Sep 4 2021, 09:53 AM
Justinp71
a9Meh2OBiBY
You can see the wheel drop out of tu... Sep 8 2021, 06:40 PM
Jetsetsurfshop
[quote name='Jetsetsurfshop' post='2942982' date=... Sep 10 2021, 12:06 PM
ChrisFoley Obviously it had years of service at the mid to up... Sep 5 2021, 08:23 AM
Jetsetsurfshop
Obviously it had years of service at the mid to u... Sep 6 2021, 10:59 AM
stownsen914 I put a Speedway Engineering bar on the front of m... Sep 6 2021, 12:25 PM
ChrisFoley
I put a Speedway Engineering bar on the front of ... Sep 8 2021, 11:37 AM
stownsen914
I've been offering a 914 front anti-sway bar ... Sep 10 2021, 07:31 PM
blabla914
[quote name='stownsen914' post='2943457' date='Se... Dec 10 2021, 07:22 PM
sixnotfour https://www.jwemotorsports.com/suspension Sep 6 2021, 05:35 PM
ThePaintedMan Good to see you back on track, Shane. I'm jeal... Sep 10 2021, 12:57 PM
Jetsetsurfshop
Good to see you back on track, Shane. I'm jea... Sep 11 2021, 07:39 AM
Charles Freeborn
Good to see you back on track, Shane. I'm je... Nov 26 2021, 09:48 PM
bdstone914
I thought I'd share these pics. I never belie... Nov 26 2021, 10:44 AM
bdstone914
I thought I'd share these pics. I never belie... Nov 26 2021, 03:53 PM
sixnotfour :popcorn: Bruce Levens 962 Nov 28 2021, 05:48 PM
Cracker Years of use and abuse will take its toll - I woul... Nov 28 2021, 09:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:08 PM |
