Gawd I Hate Points, Won't keep a tune |
bbrock |
Sep 4 2021, 08:09 PM
Quick background. Engine is a rebuilt 2L with Elgin cam and Weber 40IDFs. I bought a Pertronix Ignitor 3 to avoid having to mess with points but I could only get it to work well with a NOS Bosch 050 distributor. It runs rough with a brand new Bosch clone SVDA and the OE dizzy. However, the engine runs best with the OE DVDA distributor so I'm running that with points.
The problem is that I've had to adjust dwell and timing 3 times in only 1,000 miles of driving. Each time the dwell creeps up until the engine starts spitting and farting and is a bit hard to start when warm. Readjusting the dwell and timing gets it running like a top again. So (IMG:style_emoticons/default/WTF.gif) Only thing I can think is that the phenolic block on the points is wearing crazy fast. I lubed the cam and block with high temp slicone grease and I can feel it is still on there. Did I just get a shitty set of points? |
Superhawk996 |
Sep 5 2021, 04:19 AM
914 Guru Group: Members Posts: 5,891 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Something is not right. We all ran points in the 80s and didn’t adjust them 3 times in 1000 miles.
Need to look at them. are they burning or pitting? Are they building up a cone on one contact and a crater on the other? Are the contacts meeting nice and square to one another? Bad condenser will allow points to burn. Too hot of a coil without a ballast resistor will also cause problems. Sorry you’re having to do this. I followed your dizzy saga and it never made sense why you can’t get a stable set up that the engine likes and or an electronic ignition that works well. The bottom line is I used to run points reliably and only messed with them every 6,000 miles or so. Other less likely things: points screw tight enough or stripping out? How about distributor hold down clamp; is it clamping the distributor properly without slippage? |
Lo-Fi Version | Time is now: 6th June 2024 - 04:06 PM |
