Speedo |
Senior Member ![]() ![]() ![]() Group: Members Posts: 529 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains ![]() ![]() |
I don't want to try to make these. Car is a 70 six. First up under the PET for pedals, cables and levers.
I need the little collar that supports the rod for the cold start up by the gas pedal #914 424 219 00 Next the "intermediate piece" that is the guts of the shifter U-joint #914 424 212 00 Now the two seals for the oil tank 901 107 679 10 and 901 107 696 40. And these last two...do they seal the hole from the inside of the engine compartment, or are they between the oil cooler and the inner fender. |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,570 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
The open foam seals can be made at home.
If you insist on correct appearance of a part that can not be seen (me) use hand-turned hole saws of the suitable diameter. Cut the inside hole first, then the outer. The material is often found in stereo and electronics packaging. OEM parts dimensions in pic Seal for filter console and ring same as 911 AFAIK Attached thumbnail(s) ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2024 - 08:30 PM |
