Gawd I Hate Points, Won't keep a tune |
bbrock |
Sep 4 2021, 08:09 PM
Quick background. Engine is a rebuilt 2L with Elgin cam and Weber 40IDFs. I bought a Pertronix Ignitor 3 to avoid having to mess with points but I could only get it to work well with a NOS Bosch 050 distributor. It runs rough with a brand new Bosch clone SVDA and the OE dizzy. However, the engine runs best with the OE DVDA distributor so I'm running that with points.
The problem is that I've had to adjust dwell and timing 3 times in only 1,000 miles of driving. Each time the dwell creeps up until the engine starts spitting and farting and is a bit hard to start when warm. Readjusting the dwell and timing gets it running like a top again. So (IMG:style_emoticons/default/WTF.gif) Only thing I can think is that the phenolic block on the points is wearing crazy fast. I lubed the cam and block with high temp slicone grease and I can feel it is still on there. Did I just get a shitty set of points? |
jd74914 |
Sep 7 2021, 08:24 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Totally agree-certainly worth the try for a few thousand miles. Parts are cheap anyways.
I have a feeling your issue may be exacerbated by being a bit closer to the edge than I usually ran. Given the fact that I was doing stuff on the side of the road or in my dorm parking lot a lot, usually at night, I was never breaking out a timing light or really anything but a feeler gauge. What sounded good to my ears was probably not as fine tuned as the factory specs. I do think your ultimate goal of going to MS with COP or CNP is far better. With a good crank position signal and accurate timing it’s amazing how crisp you can get even an old motor to run (only caveat here that MS crank position calculation is kinda slow with junky hardware filters so you don’t see ultimate benefits as compared to some FPGA-based crank positioning calculations, but it’s still 1000x times better than a distributor). |
Lo-Fi Version | Time is now: 1st June 2024 - 02:10 AM |
